Question about LG WM1814CW Front Load Washer
LG washer code LE or IE showing up
What does this code mean? When doing a normal cycle this code showed up
  • 5 more comments
  • sobcz6 Nov 30, 2008
    The same thing happened to me, the closthes did not rinse and spin so the clothes needed to be rung out before could be dried...what does this mean and how do I fix it?
  • shellwill7 Dec 27, 2008
    I HAVE THE EXACT SAME PROBLEM, I JUST WANT TO KNOW HOW TO FIX IT?
  • Anonymous Jan 03, 2009
    The letters LE keep coming up on the screen, what do they mean?
  • Joyceeee Jan 12, 2009
    Our LG WM1814CW washer will not always spin all the water out to end the wash cycle. It stops, with the clothes still wet, and gives the IE error code. We turn the washer Off and put it back through either the complete wash cycle or just the Spin portion and it then normally works fine, drying the clothes ready for the Dryer.
    We would also like to get a Solution.
  • ebuban Feb 15, 2009
    Same problem.
    I have the same problem.
  • l_strople Feb 26, 2009
    le code shows up during normal cycle
    President:
  • LG Master
  • 662 Answers
Press "end of cycle" for 3 seconds or till the flashing goes off . Plug off the wall for 30 minutes, machine may re-set. Code can be an indication of several issues. The most common cause is over sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Click helped if helped.........
Posted on Apr 11, 2013
LE Code continues to appear. What does this mean and how to fix problem?
Pete
Posted on Dec 28, 2008
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
LG washing machine problem.
LE is a locked motor error
make sure that all your connections are secured
Dec 29, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
LG WM1814CW Front Load Washer Logo
1,336 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
