Question about HP Office Equipment & Supplies
When trying to print an error message comes on: Ink system failure error oxc18a0201
  • HP Master
  • 541 Answers
In you go on the hp website and click on live chat they will help you
Posted on Nov 18, 2008
After changing an ink cartrige an error message read Ink System failure. Error Oxc18a0201 It tells me to turn off printer and turn back on using printer off button.
Ink system failures are a frequent issue. If turning the unit on and off doesn't help, try doing a reset. With the unit on, disconnect the USB cable from the back of the printer (and from the computer - not always required but it does help sometimes). Then remove the ink cartridges. When the screen shows Insert Cartridges, disconnect the power cord from the back of the printer. Unplugging the cord from the outlet may help. Wait 60 seconds and then plug in the power cord (first to the wall and then the unit). Turn on the printer if it doesn't turn on when the power cord is reconnected. Then reinsert the ink cartridges and close all doors on the product. Print a calibration page and scan the page if needed to complete the calilbration if prompted to print one. Reconnect the USB cord to both the computer and then the printer.
If this doesn't help, the printer needs service. If it is out of warranty, decide if the unit is worth the minimum $50 charge just to diagnose the problem and the cost to get the unit to a service center.
I hope this helps.
Jan 23, 2011 | HP Photosmart C8180 All-in-One InkJet...
I have a HP 8250 printer....wont print. I get the following messaage. INK SYSTEM FAILURE The ink system has failed and can no longer print. Refer to printer documentation. ERROR Oxc18a0201. Turn...
Best simple fix is to take out entire program thru Control panel>add/remove and restart the computer and then reinstall it. Should take only 15 minutes.
Jan 03, 2011 | Office Equipment & Supplies
I have a HP Photosmart C6180 All-in-One printer that is 3 years old. It has been a great printer for our home. Today it decided it would no longer print and I get the following message: Ink System...
I had an ink system error message on my C6180 that evolved into the printer power cycling every 15 seconds of so. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Aug 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp c7280 printhead removal
my c7280 prints anything magenta in yellow meanwhile i have a lot of magenta ink and i have not mixed ink colours too...anything magenta prints yellow.
any help in resolving this pls?
Apr 14, 2010 | HP Photosmart C7280 Laser Printer
Ink System has failed Error Oxc18a0201 Unable to copy, receive faxes, or print
The ink system failure is caused by air in your ink feed lines. We have a step by step repair guide posted on our web site at: www.ccl-la.com Look in the printer repair section. You should be back printing in less than 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer has an Ink System Failure. It says "Unable to print. Refer to printer documentation ERROR: Oxc18a0201. I do not have the documentation asked forl
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 28, 2009 | HP Photosmart C6280 Printer
Error: OXc18a0201
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Sep 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Sep 14, 2008 | HP Photosmart C6100 All-In-One Printer
235 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
