Question about Garmin eTrex Legend GPS Receiver
Legend cx same thing . It wont turn on .Tried the reset code but dont know if im doing it right . Hold page and enter for 10 sec then power ?
  • Garmin Master
  • 638 Answers
With the unit turned off, press and hold the follow buttons: PAGE + Enter on the click stick. Then press and release the POWER. The unit will power up asking if you want to release all user data. Select yes, and the unit will be reset. After the master reset, place your unit outside, so that it has a clear view of the sky for 25 to 30 minutes for the unit to acquire new almanac data.
Posted on Dec 02, 2008
I turned the talkback feature on and now im locked out of my tablet and i can't type in my pin code
Just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Mar 01, 2014 | Eviant 7" 8 GB Wi-Fi Purple Tablet Android...
I tried to change my password and i closed the page before it finished and when i tried to connect to the internet it wont work help
Perform a reset. Find the hidden reset button, usually close to power line, find a small hole with a little button behind it. Use a toopick or similar to hold down power button for at least 10 seconds. This should restore it to factory setting and default password. Google the model # and brand and "default password" if you don't already know it. If this does not work to reset it, then try this...
Hold down reset button for 30 seconds, still holding button pull the power out, keep holding button for 30 secs, STILL holding button - plug in power then release button after 10 secs.
Yes 30 secs each cycle is overkill, but allows to be sure.
Aug 11, 2013 | Computers & Internet
My daughter had a pattern password but forgot it,the tablet wont accept her email and password is there anyway we can unlock it, we have tried to go through the email process but dont work. all we get is...
Hello Jachin, if you still have this problem. Try doing a "hard reset"
- Turn off tablet
- Hold down the power and volume "down" key together
- when red text appears select "yes" by holding down power key for 10 secs.
Reformatting shall commence
Please note that this process works on most android tablets.
Hope this helps
Apr 09, 2013 | Android 4.0 Tablet PC
I have DIR-600 Wireless 150 router , I forgot the username + password when i tried to access configuration page from the web browser. Is there any other way to get to the configuration page. ?
reset the router, then go to 192.168.0.1, Username is admin, password is left blank:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2010 | D-Link DIR-600 Router
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
Cant turn service light out
Turn the key to the ignition so the bike is ready to start but DO NOT start the engine. Press and hold the SET button (the one on your left index finger, right beneath the light signal) for about 10 seconds. This way a manu will appear. Press and release briefly the SET button so that you can navigate in the menu and choose the option DIAGNOSTICS. Press and hold the SET button for 10 secs so that you select this option. It will then ask you for a code. The code should be 13432. You can input it by pressing and releasing the SET button until you see the number you want and then by holding the SET button for 10 secs to go to the next number. When you enter the code, press and hold the SET button for about 10 secs. You will then see the diagnostics submenu. Navigate to the option RESET SERVICE and then press and hold the SET button for 10 secs. It will ask if yo are sure you want to reset so select yes and press SET for 10 secs. Exit the menu. I know for sure that 13432 is the code for America and Greece but im not entirely sure that it is the same for every geographic region. If the code is wrong then you should probably ask your mechanic
Mar 08, 2009 | 2004 Aprilia Tuono 1000
Etrex reset instrucitons
If your Garmin eTrex is a Legend and you want to do a "Reset", pls try:
Hard Reset:
This was originally posted here and a wealth of other Legend information.
Alternately, this has been posted here at FixYa as well. Pls see this post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 04, 2008 | Garmin eTrex Legend GPS Receiver
Router reset
the power light of your router should go flashing once it's being reset. If it is not doing that you can try this reset.
Hold the reset button for 10 sec. while holding the reset button unplugged the power of the router, wait for another 10 sec (still holding the reset button in), plug the power back and wait for another 10 sec. and now reslease the power button.
If it still won't work you can also do a software reset with the latest version of this router, You go to the setup page and go to the administration tab and go to the sub tab that says factory defaults, just tick yes and do save settings.
Hope this one helps.
May 09, 2008 | Linksys Wireless-G WRT54G Router
The D-link di524 router was almost intalled but it never finished intalling
hard reset the box>turn on and press and hold the reset button about 40 sec>And restart the pc and check the pc dont have any static ip>and delete all temp files cookies,clear history>and do restore default
to clear all temp thing open inter net explorer-click-tools-click inter net option- >click-general-and do >and for restoring default click-advance in the top and in the bottom click restore default and apply and ok and try to login and change the ether net cord
Oct 13, 2007 | D-Link AirPlus DI-524 Wireless Router
Panasonic ID-CODE Problem
Turn unit on with remote and open screen. You will be prompted to enter a code. If you don't know the code, you can use this overide to get your unit working again. As stated above (unit on; screen open; prompting code). In the lower right corner you have a 4-way toggle used to skip track, etc. Hold this firmly to the right for at least 10 seconds and the unit should reset the code. Do not let go until this happens. Remember hold it firmly! This will work! You will need the remote to get the code prompt!
Mar 17, 2007 | Panasonic CQ-VD7001U Car DVD Player
Garmin eTrex Legend GPS Receiver Logo
123 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
