Question about Toro Lawn Mower With Toro Power Tools
Toro personal pace mower 6.5hp runs full throttle
Govener and linkage seem to be ok but engine runs wide open from the start.
#1 Taper
  • 1040 Answers
SOURCE: Toro 20016 engine surges up and down - then stalls
You have carburetor problems. Chances are the diaphragm needs to be changed and the carb. needs a good cleaning. If you need tips on carb. cleaning, let me know.
Posted on May 29, 2009
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Posted on Jun 30, 2009
  • 3740 Answers
SOURCE: mower will not start
Hi and welcome to FixYa. I am Kelly. Sounds like your in need of a serious carb cleaning session:
You engine parts manual is here:
Now lets go through carb cleaning:
Before you start.... if you have a digital camera take "close up" PICTURES of the linkages and springs attaching to the carb. If this is your first time you will be so glad you did. You can always delete them later if you don't need them. :)
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Localte the Air fuel Jet on the side of the carb and count the number of turns it takes to close the Jet adjustment until it is just snug.
4. Remove the Jet / Orifice in side of Carb (spring on screw stem)
5. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the float pivot pin.
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle valve It should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly
g. Fuel selector ON. Raise and lower float checking for free movement with fuel flow when lowered and stopped when the float is raised level.
6. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions.
Reassemble connections.
NOTE: If you have carb cleaner spray it into the side needle jet hole.
7. Install air fuel mixture needle jet in the side of the carb. Turn until closed and then back of the same number of turns it took to initially close it snug before removal.
8. BEFORE you install the float bowl inspect the bowl nut. There are holes in the side of the nut where it screws in to the bottom of the carb that must be clear. (could be no holes in yours)
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it.
NOTE: This engine was made with 2 different carbs. One had a choke the other had a primer bulb. If the primer bulb has a hole in it the engine will start then die after a few seconds.
Thanks for using FixYa.
Posted on Apr 23, 2010
  • 64 Answers
SOURCE: My mower starts when cold and runs for a while OK
it sounds like the ignition coil is shorting out inside once it gets hot. or it could be the spark plug as well.
Posted on May 01, 2010
  • 5 Answers
SOURCE: I have a Toro Personal Pace Recycler mower with a
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Posted on Oct 03, 2010
My Toro Personal Pace mower will not come up to normal full idle.
If this is a Briggs and stratton engine, there should be a screw that holds the carburetor bowl. Remove that screw and look for a hole that runs through the middle of the screw from side to side just above the treads. Clean with a thin wire or maybe a paper clip. Then clean the perpendicular hole in the screw that runs from top to bottom. Reassemble and attempt to run. In my experience, if you don't have success at this point, you can buy a new carburetor on amazon for about $20. Install and your good to go.
Good luck to you!
Apr 03, 2017 | Toro Garden
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro lawnmower model 20027. The engine starts fine, but goes to full rpms. I have closed the throttle with my finger but it goes back to full rpm operation. Everything seems fine on the mower. i just got...
"Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar" (baymee LehighValleyPA, 2009).
I'm going to try this tomorrow myself!
Aug 27, 2011 | Toro Personal Pace CARB Walk Power Mower
My Toro Personal Pace 22"
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
How do i change the throttle cable on a toro personal pace mower model 20031
Run new cable under right side of mortor put cable through throttle brake bracket hook end into slot. Then run other end to handle and hook in slot.
hope this helps.
Aug 07, 2010 | Toro Lawn Mower With Toro Power Tools
John Deere Mower Engine Issue
Sep 05, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Throttle running too slow
I have the same problem. The mower is great---always starts and runs good, but it runs to slow and you can't speed it up. I even took it all apart. There just is no throttle control. I imagine it is designed this way to keep people from working on their mowers and to require an expensive trip to the service center. It will be my last Toro for this reason.
Aug 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
458 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
