Question about Hotpoint Aquarius WF000 Front Load Washer
Led flashes on then off
When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so all of the display is on) and then goes off and i cannot use the washing machine. Is it something simple or a major fault?
Did you find out what this problem was?
Posted on Aug 30, 2007
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Hi I have a wf620 hotpoint washing machine but the led display keeps flashing how can I reset this ? Please help
I believe the main circuit module at the rear of the machine has expired. To check this is so unplug the machine and wait a few minutes. Plug back in and if the display still flashes then I would definitely say faulty main module. If you are in the UK EMW Electronics do replacements for about £60.
EMW Electronics EMW Electronics
Jan 14, 2015 | Hotpoint Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
My hotpoint washing machine wt741 will do nothing except fast spin, LED display is flashing TEST, it will not stop doing this unless i switch if off, what can i do?
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Unplug your appliance before working on it
Thank You
Sep 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
All lights on front flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If all the LED’s are flashing then you had better call out an engineer with the right test equipment because only a few LED’s should be flashing at any one time to indicate which area the fault is in. Click on the link for more Hotpoint, Creda and Indesit error code definitions or Hotpoint WMA / WM workshop manuals
Mar 05, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Hotpoint WF640P - in permanent 'test' mode?!
Press "start" & "on" together for over 5 seconds; the test mode will come off.
Dec 09, 2007 | Washing Machines
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
155 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
