Question about Brother MFC 240C All-In-One InkJet Printer
Print unable 49..
Hi, i have a brother mfc -240c and it is saying that print unable 49 but I already got the paper jam out, and I got the tiny piece of paper left in the left gear of the printer but still I receive the same error. Can you help me? What can I do? I was thinking if only I knew where the paper sensor is I could blind it so it wouldn't say any paper jam. Hope to get a reply soon.
  • ckennic Nov 26, 2008
    how do I fix it
Clean unable, how do I fix it?
Posted on Nov 26, 2008
Unable to print.49
The error indicates that there is a mechanical problem. Open the printer and look inside for any staples, paper clips, torn pieces of paper, etc.
Hope this helps. Please rate this solution
Randy
Oct 10, 2012 | Brother Sealed Mfc-j430w Wireless Printer...
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Brother MFC-5440CN, unable to print
Unable to print is usually a paper jam either in the far right or the far left of the carriage assembly, you need a flashlight to inspect for paper scraps caught at either end of the carriage travel area.
Sep 04, 2009 | Brother Multi-Function Center MFC-240C...
Print Unable 4F
The most common cause is jammed or shredded paper. Check for tiny pieces of paper throughout. Hope this helps.
Jul 14, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have the same problem. Most people i asked about it said it is a mechanical problem. It's better to bring it to a brother service center near you.
Feb 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
May 03, 2008 | Brother Multi-Function Center MFC-240C...
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC 240C All-In-One InkJet Printer Logo
996 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
