Question about Logitech Z-5500 Computer Speakers
Z 5500 i want to get out the cover of bass how can i take off?
There are four screws visible that have to be taken out of the plastic. There are also six or eight screws under the screen cover. You have to drill holes in the screen and unscrew the sub. The plastic holding the screen is screwed down underneath the sub.
Posted on Jan 07, 2009
A29639
Wow, what a veteran. It is older than my 1964 bass. Your guitar was made at the Kalamazoo Plant, MI, USA in 1959, Production Number: 29639. In good condition it would be worth up to $5500, which I think is shamefully low.
Aug 31, 2014 | Gibson Music
Volume goes up by itself
First, check your software firmware version and see if there is an update. If available read your manual how to do a firmware update using your USB port, if you don't have a manual, check Bose.com for their online manual and firmware updates. I had a different problem but the firmware update solved it. Another tip to increase the depth of your bass, while doing the adaptiq process, cover your bass speaker with a pillow, this will make your bass more deeper. You need a second person to cover your bass module with a pillow. in this way, the adaptiq process cannot hear the bass sound and it will increase the bass. You might need to do this several times until you get the desired bass sound. If you have not setup using adaptiq, your better off not using adaptiq, the sound is much better. Hope this helps.
Nov 18, 2013 | Bose Lifestyle V25 Theater System
Mtx mxa 6001 amp cant get it to produce good bass using mtx 5500 subs running a 2ohm load
You seem to have everything in spec. check your crossover points and your speaker wiring. subs may be playing out of phase.
A huge factor is subwoofer enclosure ...if the enclosure is not in spec with sub requirements the subs will not peform great.
Sep 23, 2013 | Car Audio & Video
I have a problem with my z-5500! the bass is really bad, on all the effects. my friend has the same pare of speakers han his bass is really good. what should i do???
Always make sure that your computer settings for audio are checked and set accordingly and that all the equlizers and audio programs that are installed and controlling your audio sound output are accounted for and adjusted properly.
Feb 07, 2012 | Logitech Z-5500 Computer Speakers
Cant get the bass i want.
Try checking the specs on the amp. It might not be able to drive a 2ohm load. just a suggestion.
Mar 31, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sound only comes out of 2 out of 5 speakers. I've had a previous set of these and they also had the same problem.
Do all of the speakers plug into the bass, then from the bass to the computer? Seems like the multimedia controller you have right now is either not working or was never meant for that many computer speakers. In this case, you might want to get a sound card. Sound cards will let you plug the sets of speakers (Front, Rear, Sides, etc.) into each of the inputs on the sound cards. The jacks and inputs will be colour coated so you know which one to plug into which one.
Mar 08, 2010 | Logitech Z-5500 Computer Speakers
How do i wire up my mtx 15 5500 sub woofer dual voice coil any one know i have tried several ways
there are several ways, it all depends on the bass response you want, and with that, it also changes the ohms in the amp. i'm going to give you seval ways to hook them up. if you are running more than one just follow these steps per sub. the first one is if your sub is dual 2 ohm. Wiring Option #2
1_2ohmdvc_1ohm.gif Wiring Option #2
this is for dual 4 ohm coils
1_4ohmdvc_2ohm.gif Wiring Option #2
Mar 06, 2010 | MTX Thunder 5500 T5510-04 Car Subwoofer
Adcom GFA 5500 right channel emits horrible sound. Broken highs and no bass. Is is repairable by a semi amatuer?
Adcom makes a great amplifer! Usually broken highs and no bass means blown speaker. Try hooking it up to a completely different input source. Try different speakers also. If problem persists, check the fuse. Most will have a fuse on the back you can screw out. Some have two fuses (one for each channel) If this doesn't fix the problem it could be expensive to fix. Also, does this model ave the thermal protection light and if so, does it come on at all?
Jun 22, 2009 | Adcom GFA-5500 2-Channel Amplifier
Woofer popping
Sounds like a loose connection or a blown speaker. I would try just playing around with the wires to see if you can make it pop, if so, the wire you were messing with is the most likely culprit. Also, verify the sub cone has no damage or cracks. I am betting it i a bad connection or a loose wire.
Jul 21, 2008 | Logitech Z-5500 Computer Speakers
Replacing 5500 cover
Hi Stew,
I Have found a internet site on how to change covers on moblie phones this is the link www.lovehopefaith.com/v70help.htm you can try it`s got drawings of all moblie phones and how to take them apart I hope this site is helpful to you.
Jan 16, 2008 | Nokia 5500 Sport Cellular Phone
Logitech Z-5500 Computer Speakers Logo
62 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
