Question about Kenwood KDC-M7024 CD Player
TOC Error If i put an audio disc that i have recorded, or a disc with MP3 on into my player, all i get is TOC error. It works fine with original cd's. When this unit was new it worked fine, but this has happened recently. the unit is two years old.
  • AFPM Nov 18, 2007
    i have the same problem and mine have the same age :(
I had the same problem with my KDC-M7024 CD player. All I done was put a cleaning disc into the player and let it play for 2-3minutes. The disc has a small cleaning brush on it which spins around like a normal CD would and as the bristles pass over the laser it removes any dust.After that it worked fine but i still have to run the disc through every 3-4 months or the problem persists.
Posted on Nov 21, 2007
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Cd wont play after finalize an toc error C14 appears
You can visit this link to check it this error out.
toc error C14
Best regards.
May 26, 2009 | Sony RCD-W500C 5-Disc CD Recorder
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
Kenwood KDC-MP528 CD TOC ERR
Every one of those Kenwoods that I have fixed with that error needed the laser pick up replaced. so there is no easy fix for it.
If you have tried several disc's and they all have a TOC err, and you know the disc's are in decent condition, then you will need the pick up replaced.
First try cleaning the disc you are using. I use windex and a soft cloth like a bath towel, it works great at getting fingerprints and other stuff off the disc without scratching the disc. A bad fingerprint or a bad scratch right at the innermost part of the disc (where the TOC is located) will cause any CD player to not read the TOC, producing a TOC ERROR. you never know, you might get lucky.
Jun 17, 2008 | Kenwood KDC-MP528 CD Player
E-99 and other times time TOC ERROR shows up.
hi TOC error sounds like its the laser is faulty. you could try a cd cleaning disc. this may cure the problem..
Regards
Mark
www.blueice-electronics.co.uk
Feb 25, 2008 | Kenwood KDC-MP205 CD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KDC-M7024 CD Player Logo
222 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
