Hotpoint Aquarius WT740 Fault Code F-05. What does this mean?
  • bluedevilwin May 26, 2009
    Does 8888 mean anything when trying to use my machine it shows the cycle then comes up 8888 and does not start.
  • Washing Mach... Master
  • 3,463 Answers
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
Posted on Nov 20, 2008
2 Suggested Answers
SOURCE: fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny noise...like some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
Posted on May 24, 2009
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Fault Code F-08. What does this mean?
F08 means Heater relay stuck: check pressure switch, heater & module connections..
Dec 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault code stopping washer from working
May 24, 2009 | Ariston Technologies Washing Machines
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint error f10 on model wt740
F10 us usually a stuck key on the keypad. Turn the power off to the machine or kick the breaker off, press each button a number of times to make sure they are not sticking. If you find one sticking try to pop it out. Turn the power back on and try to use it. If the f-10 code returns you will need a new touchpad. Good luck to you and I hope this helped you. Mike Anderson
May 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
1,014 people viewed this question
Top Washing Machines Experts
