Question about Philips Magnavox 51MP392H Rear Projection Television
Bulbs Can I Replace Bulbs?
Where do i get a bulb?
Posted on Jan 24, 2009
    Scholar:
  • 146 Answers
Yes you can. It is very easy to do. You can get the full detail of how to do so in your owners manuel. If you do not have yours let me know and I'll see if I can look it up for you on the internet.
Posted on Nov 18, 2008
I replaced the tail light bulb but keeps beeping
You often have to replace both tail light bulbs and replace them with identical bulbs. I prefer the nickel-plated bulbs (rather than the brass base) with the elliptical contacts, generally these are marketed as 'european' bulbs.
Sep 01, 2014 | 1999 Audi A4
Can I replace the 3 40 watts bulbs that came with my Hampton Bay Hawkins 44" ceiling fan with 3 60 watt bulbs?
You would be better off getting 3 40watt daylight bulbs.. extreamly bright low cost and wont cause any harm to your fan.. hope this helps :)
Oct 21, 2011 | Dryers
I have a 2005 chev impala can i replace my high beams headlights with just low beam lights
NO YOU HAVE TO REPLACE HIGH BEAM LIGHT BULBS WITH HIGH BEAM LIGHT BULBS BECAUSE HIGH BEAM LIGHT BULBS AND LOW BEAM LIGHT BULBS TWO DIFFERENT TYPES OF BULBS.WEAR CLEAN LATEX GLOVES HANDLING THE HEADLIGHT BULBS WHICH IS HALOGEN LIGHT BULBS, OIL FROM FINGERS OR HAND WILL CAUSE HALOGEN BULBS TO OVER HEAT BLOW OUT.
Jul 05, 2011 | 2005 Chevrolet Impala
Need to change bulbs in headlights on a 2004 kia amanti
LOOK IN GLOVE COMPARTMENT FOR OWNERS MANUAL.LOOK IN THE BACK INDEX OF MANUAL LOOK FOR BULB REPLACE IT WILL SHOW YOU HOW TO REPLACE HEADLIGHTS BULBS BULBS ARE HALOGEN YOU NEED TO USE CLEAN LATEX GLOVES WHEN HANDLING AND REPLACING BULBS BECAUSE OIL FROM YOUR FINGERS OR HANDS WILL CAUSE HALOGEN BULB TO OVER HEAT AND BLOW AND HALOGENS BULBS VERY EXPENSIVE. THEY CAN RUN PRICE RANGE FROM $10.00 - $20.00 DOLLARS.
Jun 15, 2011 | Kia Amanti Cars & Trucks
I have had to replace both the headlight bulbs 3 times!!!
this is not uncommon for these vans. when you install the headlamps be sure not to touch the bulbs with bare hands. use latex gloves. the oil from your hands will diminish the life of the bulbs. when your done with the bulb issue have your charging system checked for an overcharge(anything over about 14.7 volts). if the charging system is in good shape, i would seriously consider the quality of the bulbs. happy holidays
Dec 31, 2009 | 2006 Kia Sedona
All bulbs are burned out. Need to replace.
if only bulbs required normal bulbs will do if bike is 12 volt.
Aug 25, 2009 | 1988 Honda GL 1500 Gold Wing
How do you replace bulbs in the trunk
if we do it.some times the bulbs will be damaged.so the better way is to go to the near by workshop to replace it. thanku
Jul 19, 2009 | 1984 Buick Regal
Replace low beam bulbs on 2003 s10
2003 s10 replace low beam bulbs, was 2 clips that are attached that you pull up and the head light will tilt forward, to replace pulp,
May 19, 2009 | 2003 Chevrolet S-10
How to replace 1998 Ford Contour headlights (with diagram)
Step 1
Remove your Contour's front grille. You can do this by raising the hood and removing two screws that are located on top of the grille.
Step 2 Remove the headlight assembly. The headlight assembly is held into the front of your Contour by three screws. Two screws will be located on top of the assembly, and one on the bottom.
Step 3 Replace the headlight assembly, if necessary. If you are only changing individual bulbs, make sure you replace the correct bulbs. Each assembly holds three light bulbs, including the bright, dim and turn signal bulbs.
Step4 Replace the headlight assembly and reattach the three screws to hold it in place.
Step5 Replace the front grille of your Contour and the two screws that hold it onto the front of the car.
  • It is usually a good idea to replace bulbs together (in pairs). This will allow the bulbs to wear at the same rate.
  • If you choose to replace only the individual light bulbs, do not touch the new light bulbs. The contact of your skin on the bulbs will cause the light bulbs to burn out much sooner.
Let me know if you have any further questions.
Benjamin
Apr 26, 2009 | 1998 Ford Contour
Philips Magnavox 51MP392H Rear Projection Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
