I have an Acer notebook which is stuck on page 3 of 3 on an update since a power cut. There is no recovery disk and all options have been exhausted in the re-boot option. Any help would be grateful as I am technologically challenged.
  • kazza7 Nov 18, 2008
    Thanks for trying but have attempted to re-boot the system on numerous occasions, attempting to use all the recovery devices installed with the notebook and even tried returning it to it's factory settings but still nothing works. Help please!!!
  • 849 Answers
Use ctrl+alt+del keys to open task manager, if it opens the choose end task after selecting the required task to end. if nothing happend the u have to re-boot the system.
Posted on Nov 18, 2008
Acer travelmate 4202 recovery disc
You can, if available, purchase a Recovery disk from Acer. That said, if you have a Recovery Partition, By rebooting and using the restore/recovery ALT+ F-10 keys. On page 59 : http://support.acer.com/acerpanam/manuals/acer/0000/userguides/TM4200-ENG-OLM_1207.pdf and this may be useful: http://support.acer.com/us/en/product/default.aspx?tab=2&modelId=774 IF you are doing a Factory recovery on a XP Machine, I would put on a pot of coffee. I recently did the same, with hundreds of Windows and Computer manufacturer's update it took 36 hours stright. Good Luck.
Dec 23, 2012 | Acer TravelMate 4230 Notebook
I need to restore my acer 5610z laptop back to factory settings
To restore my computer to its original settings without
recovery CDs.
Note: If your system is the multilingual version, the operating
system and language you choose when you first turn on the
system will be the only option for future recovery operations.
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST.
37
English
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press + at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 3 to 4 GB in a hidden partition
on your hard disk
Thanks for choosing Fixya
Mar 17, 2011 | Acer Aspire 5610 Notebook
How do i reset my laptop back to factory settings
The disc that you should have received with the laptop should give you this option. Just put it in and reboot and it will bring you to a menu with a few different recovery options to choose from.
Feb 28, 2011 | Acer Aspire 5500 5570-2609 Laptop
I just restarted my HP and now it says there is no hard drive and I dont have a recovery disk
try disconnecting the drive and reseating it first.
If you enter the bios (f10 on startup) does the computer even detect the drive? If not - try reseating it - don't forget to power off first
Failing that try the hp recovery partition
Press the power button to start the HP. Press and hold the F11 key to launch the HP Recovery Manager from the recovery partition.
Backup any files you want to save. Follow the HP Recovery Manager instructions to save any important files before continuing with the recovery process.
Continue the recovery process. After backing up files to an external device or CD/DVDs, select the option to perform a system recovery.
Obtain and install updates for the HP. After your system reboots, use HP update manager as well as Windows update to restore all critical updates to your HP computer.
5
Make a set of recovery disks. Use HP Recovery Manager and select "Advanced Options" to create a set of recovery disks that can be used in the event that your HP cannot access the hard drive.
Feb 25, 2011 | HP G60-235DX Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hello i went to restore my acer and now it's stuck when i turn it on first you see acer screen then it goes to starting acer recovery management then windows xp screen and then it says please wait then it...
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Dec 20, 2010 | Acer Aspire One AOA150-1635 Notebook
I have an acer aspire one D250 laptop and I tried to reboot and restore it. Now it lead me to a blank page that says B00TMGR is missing.press Ctrl alt del to restart. I tried to use ALT F10 and nothing...
*** Remove any external monitor as it will make entry into BIOS utility and recovery process difficult. ***
The following is from pages 29-30 of the 52-page D250 UserGuide.pdf located in folder C:\Book
I want to restore my computer to its original settings without recovery CDs.
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
1. Check to see if Acer disk-to-disk recovery is enabled or not.
2. Make sure the D2D Recovery setting in Main is Enabled.
3. Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST (Power On Self Test).
1. Restart the system.
2. While the Acer logo is showing, press + at the same time to enter recovery process.
3. Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 6 GB in a hidden partition on your hard disk.
Sep 30, 2010 | Acer Aspire 3050-1733 Notebook
Where can i buy a recovery CD for my Acer Extensa
Note: To activate the BIOS utility, press <F2> during POST.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
Important! This feature occupies 10 GB in a hidden partition on
your hard disk.
Apr 09, 2010 | Acer Extensa 4620 Notebook
I am downloading updates for vista nd number 3 of
Had the same problem on 2 laptops. One I used recovery disk to repair windows(can be done through inbuilt recovery on F12 at start-up). The other needed to completely reinstall windows with recovery disk losing all files/docs on laptop.If you need any help please ask
Oct 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
Stuck on configuration updates stage 3 of 3, for the past 12 hous, keeps shutting down but coming back to same screen
sp1 has been corupted this is comon problem use your acer recovery disks and use the repair my computer option on vista and go back to a previous system backup which should be just before sp1 started to install hope this helps
Oct 09, 2009 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
26 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
