Question about JVC TV-20241 20 in. TV/VCR Combo
The on timer is flashing and the TV will not come on. It is a TV VHS combo set. How can I reset this timer so the TV will turn on? Power down and back on does not help. Thanks,
  • JVC Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
On your VCR combo also ensure that there is no tape inside the VCR.
Posted on May 05, 2009
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
My RCA 42 " LCD Is crazed. i USE THE REMOTE TO TURN IT OFF AND ABOUT A MINUTE OR 2 LATER IT AUTOMATCALLY TURNS ITSELF BACK ON. THE ONLY WAY I CAN KEEP IT OFF IS TO UNPLUG FROM POWER SOURCE. IS THERE A...
Check the sleeper timer is not on like 30,60,120 Mins.Turn the sleeper function off,should work.Not,go in ur tv menu,go to PICTURE,go down to reset the tv Tuner board,the setting will go back to the factory setting.
Jun 18, 2010 | RCA L32WD26D HDTV/DVD Combo
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
V chip reset
i need to reset my sons v-chip how do i do that,he has a toshiba tv.
Sep 27, 2008 | RCA T20TF667 20 in. TV/VCR Combo
I have a toshiba tv model:19a21 and i want to unlock the v-chip. i did not activate the v-chip i was like that when i bought the tv what can i do to reset it
To reset the V-Chip on the Toshiba 19A21:
Hold the volume down on the TV - at the same time, press the number 1 on the remote. The TV will turn off and reset everything.
Jun 22, 2008 | Toshiba Televison & Video
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Wont turn on
OK, it looks like a power supply problem. The click you are hearing might be the shutdown relay connected to the overcurrent circuit. This might be indicating a problem in the Hv section of the TV. To get the tape out you can restore the power supply or what you could do is to try to access the drive motor and find the load and unload gear and try to turn it to take the tape out, this has worked in the past at my shop. If you have no experience in electronics I would suggest you not trying to repair this set because of the danger involved. Take it to a qualified repair shop.
Sep 17, 2007 | Sylvania 6313CA 13 in. TV/VCR Combo
JVC TV-20241 20 in. TV/VCR Combo Logo
154 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
