Reset the lamp timer on PJ506d
How to reset the lamp timer on PJ506d, I can´t reset my projector´s lamp timer.
  • Anonymous Feb 26, 2009
    I replaced the Lamp in my Viewsonic PJ506D projector now I can't reset the Lamp hours.
    Problem Solver:
  • 5 Answers
Here's the manual
www.aboutprojectors.com/pdf/viewsonic-pj506d-manual.pdf
On page 24 in 'Advanced Mode', it tells you how to re-set to factory settings, and that will probably include zeroing the lamp hours.
If not, there seems to be nothing else there.
Posted on Nov 23, 2008
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Resetting the lamp timer on an infocus in24 projector
To reset the lamp timer on an in24 go to settings, then select Service. The option to reset lamp hours should be in this menu.
I hope this helps!
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 04, 2014 | InFocus Office Equipment & Supplies
I have ViewSonic PJ506D DLP Projector it will power up but the lamp wont come on relaced lamp still have problem
Check the power supply , it can be a fault on the power being inadequate or there is an error to the processor that seems to cut off power. try and check the lamp connections, check the lamp door switch, the filters- clean if dirty
Oct 18, 2011 | ViewSonic PJ506D DLP Projector
How do i reset timer on marantz projector VP 4001
Hello
you want to set the Lamp timer after replacing the Lamp I thinks and posts this solution.
[1] Connect the power cord into the AC socket of the projector.
[2] To reset the Lamp timer; While simoultaneously hodking down "MENU, ENTERAND DOWNWARD Button" on the projector, press "POWER/ 'STANDBY/ON on the projector.
* "LAMP 0000H" is displayed indicating that the Lamp Timer is reset.
If you want anymore assistance from me, get me by FixYa. OK.
Sep 19, 2011 | Marantz VP4001 DLP Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Projector does not start, standby lamp and lamp indicator still remains on after replacing new lamp
Have you reset the timer?
Reset the lamp timer.
• While simultaneously holding down
MENU/HELP, ENTER and R on the projector,
press STANDBY/ON on the projector.
• “LAMP 0000H” is displayed,
Jun 12, 2010 | Sharp XR-30X Projector
The projector start to turn on but the lamp led turns into amber blinking and then it shuts off
the lamp has reached the end of it's life. replace it and reset the lamp timer (through the menu).
Sep 02, 2009 | ViewSonic PJ506D DLP Projector
Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Aug 19, 2009 | ViewSonic PJ506D DLP Projector
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Jul 09, 2008 | Office Equipment & Supplies
Lamb will not reset
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
1,995 people viewed this question
