Question about Zebra TLP 2844-Z Thermal Label Printer
Printer will print everything but barcodes
I clicked on the "build barcodes" icon but it still will not print the barcodes
3 Suggested Answers
SOURCE: Barcodes print too long
This is defendant on the program you use to print labels with. The printer responds to either a print job sent to the driver (like a standard windows printer). Or you can send an EPL program to the printer in order to use internal barcode generating features of the printer. The dimensions of the barcode are controlled via the EPL script. See the EPL programming guide avaialble on Zebra's website for more info.
Posted on Jul 28, 2008
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Can't process printing
first remove the power plug and the usb from the printer wait for few minutes and place them back first the power then the usb then press start setting printer and go to printer propertes in printer page you will see the printer drivers which are instaled make the prinriter you are using as defult if you see no printer drivers then install the software which came with the printerall the printer software should be installed then go to the taskbar you will see the printer icon click them to open then delete all the contents then click to close then go back to the printer page right click the defult printer and click tgeneral in general you will see print atest page click it
Jul 03, 2011 | Computers & Internet
Prints one or two lines then you get a scrambled error message and it stops until you press on button then it does the same thing again, I have unplugged everything several times and even uninstalled and...
Use the HP Toolbox to perform the following tasks:
  • Calibrate the printer to align the print cartridges.
  • Clean the print cartridges when lines and dots are missing from your printout.
  • Print a test page to check for clarity after cleaning or to verify that the printer can receive data and print from the computer correctly.
  • Print a diagnostic page to show how the print cartridge nozzles are working.
  • Calibrate the photo tray to correctly position your photos.
  • Check the ink levels of the print cartridges. Adjust the printer configuration.
  • Investigate warning conditions.
Opening the HP Toolbox from the printer icon
  1. Double-click the HP Digital Imaging Monitor and make sure you are on the correct printer tab.
  2. Click Settings and then click Print Settings .
  3. Click the Printer Toolbox choice.
Opening the HP Toolbox from the Printer Properties
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Printing Preferences .
  6. Click the Features tab.
  7. Click the Printer Services button.
Oct 25, 2010 | HP PSC 2355v All-In-One InkJet Printer
Hello, my HP Deskjet D1560 goes offline every time i connect the printer to my Computer, i already installed the updated driver..... Kindly solve my problem Thank you
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Aug 02, 2010 | Computers & Internet
I have HP 1200 psc I have a document that will not delete therefore I cannot print anything at all I have tried switching off everything - no luck - can you help?
From Printers and Faxes window
1. Right click the printer icon for your HP 1200 PSC then select "Set Printer Offline".
2. Right click again the printer icon then select "Cancel All" print jobs.
3. Once it's cleared, right click the printer icon again and then "Set Printer Online".
Or, restart the computer and the printer.
Oct 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Everything prints backwards...
Click on start and then click on control panel.
open the printers and faxes folder and right click your printer icon and select properties.under the ports tab remove the check that says bi-directional printing.Click on ok.
Once again click on the printer icon and select printing prefrences.Goto the advance tab and one of the options will say front to back/back to front the (only 2 options) select either and try to print and this should resolve your issue
Jun 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My hp psc 1610 printer will not print
1. Click the Start icon, click Control Panel, click Printers and faxes folder.
2. Right Click on the printer icon and Select Properties.
3. In Ports tab of the properties window, check the box beside "Enable bi-directional support".
4. Click OK to confirm the changes.
Feb 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
Prints text backwords on text files
click on start go to control panel
click on printers and under printer look for the printer icon
right click on the printer icon for your printer and select printing preferences
click on advance and look for mirror image
turn off mirror image and click apply
try to print afterwards
Oct 20, 2008 | HP Officejet J5780 All-In-One InkJet...
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Printer won't print from computer
Start from the beginning. Check that everything is connected between the computer and printer. Be sure the power is on. In Windows XP, go to the control panel and find "Printers and Faxes". Double click on that. If you don't find your printer in the list of printers and icons, click on the "Add Printers" button on the left column. Follow the steps to install your printer. When you print, make sure the printer is selected. If you have more than one printer icon (and you only have one printer), right-click on the icon for your printer, and find the button that says " Set As Default Printer". Click on that so that the printer is the one that will print your files. You'll see a check-mark next to the icon which indicates that it's the default printer. If you have multiple icons for the same printer, delete the ones that aren't being used.
Once your printer is set up properly, try printing something to be sure it works.
If it doesn't and you can't figure out what's wrong, you may have a faulty cable. Try another one.
When you go to print you file, click on "File", then "Print". Then you can see which printer is going to be used. If your printer isn't shown in the box at the top, click on the scroll box and see if your printer is there. Click on it if you see it in there. If you simply click on the printer icon on the tool bar, you won't know which printer has been selected. Use the "File" and "Print" commands instead to gain access to more information about your printer selection, paper type, preferences, etc. Good luck!
Apr 08, 2008 | Office Equipment & Supplies
Zebra TLP 2844-Z Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
