Question about ViewSonic VX724 17" LCD Monitor
Monitor failure When I turn on the computer the monitor flashes on and off for a few seconds and in the bottom right hand corner you can see the word analog and then the screen will go blank and the monitor shuts downand can not be turned back on
  • 3 more comments
  • M3thod Nov 11, 2007
    my viewsonic v724 is crazy when i went to bed it was fine when i woke up it was in normal sleep mode wheni tryed to take it out it began to power on and off on and off tryed to reboot and all diff connections i can see flashes of the loading windows screen but the power lights clikcs on and of rapidly anyone have an idea of what is wrong if i can fix it or just buy a new monitor this problem is robbing me of my gaming time can anyone help
  • kblee May 18, 2008
    same problem. anyone has a solution?
  • Anonymous Jul 22, 2008
    i got the same problem power and screen blinks on and off
  • SigurdVader Apr 16, 2009
    Traceelectro,
    I have exactly the same problem on the VX724 I purchased April 2006.
    I have already replaced a few electrolytics that have dried out and bloated but still the on/off cycle continues.
    Care to share which transistors did you replace? They're my next target.
    Thanks!
    SigurdVader
  • 21 Answers
I have just cracked open a Viewsonic VX724 monitor with the same problems mentioned above. This is a power supply issue. As I am a technician I can repair my power supply by replacing a few capacitors and a couple of surface mount transistors on the back of the power supply PCB. If you aren't a technician than I would suggest you weigh the cost and either source a new powersupply and install it or scrap your monitor.
Dillon, Trace Electronics, Barrie ONT, Canada
Posted on Apr 11, 2009
  • Dillon Blake Apr 20, 2009
    The power supply has 2 circuits that drive the back lighting for these monitors - Identified by the small connectors that you have to unclip when you remove the power supply. Well, there are two small step-up transformers directly infront of these small connectors. If you notice a brownish burn-in on your board then the side with the browning is the faulty side. Replace the transformer...and the two small transistors directly underneath on the solder side of the PCB. I am still researching,,trying to find a xformer. I would normally get these from a scrap board...but no boards here.
    Trace Electronics
There are bulbs that light up the display so you can see it on the inside. They go out, just like the bulb in your bathroom. No way to fix this and get the dam thing back together. Toss it and get a new one. I've got photos of the one I took apart. It's a mess. But very cool to look at.
Posted on Dec 12, 2008
SOURCE:
How to turn off monitor
1. Go to the desktop
2. Right Click
3. On that list, you should click personalize
4. In the lower right hand corner, click Screen saver (It's in blue letters)
5. In the bottom left hand corner of the window that just popped up, click "Change power settings"
6. In the left side of the new window, (It's in the light gray area) click on "Change when the computer sleeps"
7. Then from here you can set when you want to turn off the display and or put the computer to sleep after how long you have been inactive.
8. Remember to click the "Save changes" button to save what you've done.
May 25, 2014 | Total Gym Cyclo Trainer
My E19T6W 19" LCD monitor
Sorry, I have no solution, just thought you might like to know that I am having the exact same problem.
The only thing I can add is that it appeared after a night that my computer was set to do a weekly upload of Microsoft, anti-virus and anti-spyware updates. Also, that night we had some electrical storms. The menu pops up in the bottom right corner at very erratic intervals and sometimes just flashes, while other times stays on for minutes. It is driving me crazy!
I have tried updating the monitor driver and the video card using the "Device Manager" icon found in the "Control Panel". No luck. I have also ran anti-virus and anti-spyware scans and also used AVG to scan and fix registry errors. No luck.
I am open to suggestions.
Thanks
Nov 07, 2010 | eMachines E19T6W 19" Monitor
Cant turn monitor back on
broken power switch... .. the "friend" broke the power switch by pressing too hard or as luck had it the switch is broken..
recommend leaving the monitor unplugged for 4 hours
open the case of the monitor up and pull the small circuit board for the "buttons" out and get a replacement board... google the part number exactly as spelled out on the little button board
Sep 28, 2009 | Computers & Internet
Out of range message
check the unit/CPU to the others monitor or open then make a clean the VGA card and Memory..good luck
Jun 25, 2009 | X2Gen MG17J 17" Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Possible monitor or graphics card malfunction
The monitor is bad. The flashing is telling you that something inside the monitor has gone out. If it is still under warranty they should either fix your monitor or give you a replacement. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | Computers & Internet
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
ViewSonic VX724 17" LCD Monitor Logo
370 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
