Question about HP LaserJet 1320n Printer
Printing problem with HP laserjet 1320
Hai
We are using hp Laserjet 1320 printers which are connected in lan, and when print command is given the following error is printing on Page
PCL XL error
subsystem: kernel
error: illegal tag
operator : 0x1b
position : 6
We are facing with all the printers which are connected to the LAN( HP Laserjet 1320). Please give us the solution to over come this problem
Ravishankar
Pioneer Cements UAE
  •  Abhay Pujari
    Abhay Pujari May 11, 2010
    How did you setup this in lan? I wish to know your configuration and the steps you are following for the same.
    Scholar:
  • 61 Answers
I've seen this error on this model in the past. I was only able to resolve the issue by replacing the formatter board. Hope this helps.
Posted on Aug 31, 2009
    Scholar:
  • 74 Answers
Hi
when i had this i downloaded the post script driver instead from the hp website and that solved it.
The printer talks both languages and it just send the file in a different way - looks totally identical (as you would hope)
Posted on Aug 28, 2009
    Sniper:
  • 87 Answers
Hello Ravi,
Please change the current driver from PCL 6 to PCL 5. Install the Universal printing Driver.
Find the link below:
For Vista, XP, 2003:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=410622&prodNameId=410633&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ja-35999-16
regards,
Nikhil
Posted on Aug 25, 2009
    Novelist:
  • 102 Answers
I If you says that the printer the connected of the network than if you are using Server than it is Windows Server 2003 and on client machines you are using Windows XP.
And at the same time you are using PCL Printer drivers.
If yes than download and install PCL 5 Driver from the link below and in m sure issue will be resolved.:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=410633&prodTypeId=18972&prodSeriesId=410622&swLang=8&taskId=135&swEnvOID=228
Posted on Jul 02, 2009
  • 30 Answers
Try changing the lan card to another one
Posted on May 18, 2009
  • 385 Answers
Hope this helps you troubleshoot it.
Link
Regards.
Posted on Apr 17, 2009
My hp laserjet 1320 printing is printing too slow
If you're running a Mac, when you try to install the LaserJet 1320, it may suggest that you use the driver set for "HP LaserJet 1320 Foomatic/pxlmono." Do not use those settings. I had to reinstall my 1320 recently and since it said that was the recommended choice, I selected it. If I printed just text, it worked fine, but even a tiny 50KB image would take 5 minutes to print. When I reinstalled it again, I selected the option "HP LaserJet 1320 series," and everything works just fine now.
Apr 12, 2012 | HP LaserJet 1320 Printer
HP Laserjet 1320. Will not stop printing and not showing up in the Que. I have unplugged overnight, I have cancelled all jobs in the Que and will not stop printing. How do I cancel the job
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click START
Click RUN
Type CMD ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 07, 2010 | HP LaserJet 1320 Printer
When printing envelopes the printer suddenly prints fact sheet
have you updated the firmware on your printer? hp has a firmware update utility down load for it that just might help you with your problem. iu fixed a simular problem by using the download
Jun 03, 2010 | HP LaserJet 1320 Printer
Printer gets jammed in the middle of printing
My printer get jammed with a thick paper. I cannot see where the paper is.
Jan 23, 2010 | HP LaserJet 1320 Printer
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
Printng error
Please change the driver to UPD (http://www.hp.com/go/upd) to PCL5
This will solve the issue
Rgds,
Nikhil
Jun 14, 2009 | HP LaserJet 1320n Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
404 people viewed this question
Seeker5211
Seeker5211
