Question about Lands Phones
How to format the samsung E250??????????????????
I  hve to format my phone which is samsung e250give me the reply plz...
  • 5 more comments
  • parth_loveu Nov 18, 2008
    and send me the link from which i can download free games, software,,theames for samsung e250
  • ravisingh250 Feb 21, 2009
    how to format mobile model samsung E250
  • Anonymous Mar 11, 2009
    I NEED TO FORMAT MY PHONE *******
  • sri_balaji76 Mar 24, 2009
    how to format a Samsung E250 Moblie plz reply the post
  • Anonymous Apr 21, 2009
    MY PHONE IS NOT SWITCH ON
  • MILAN_PANDYA Apr 21, 2009
    MY PHONE IS NOT FULLY SWITCH ON ,IT RESTART
  • Anonymous May 26, 2009
    i hve a mobil samsung e250 i hve to re format dat pls give me a solution
My key of mobile do not working and i went to samsung serives center then told me your software is corrupted .
so you send me format code of samsung (e250)mobile
Posted on Dec 11, 2008
  • arcd Dec 11, 2008
    my key of mobile do not working and i went to samsung serives center then told me your software is corrupted .
    so you send me format code of samsung (e250)mobile.
MY PHONE WORKS SLOWELY
Posted on Mar 05, 2009
Voila code *2767*3855#
Posted on Aug 05, 2009
  • daoui50 Aug 05, 2009
    liste cod et vive maroc
    *#1111# S/W Version
    *#1234# Firmware Version
    *#2222# H/W Version
    *#8999*8376263# All Versions Together
    *#8999*8378# Test Menu
    *#4777*8665# GPSR Tool
    *#8999*523# LCD Brightness
    *#8999*377# Error Menu
    *#8999*327# EEP Menu
    *#8999*3825523# Don't Know.
    *#8999*667# Debug Mode
    *#92782# PhoneModel (Wap)
    #*5737425# JAVA Mode
    *#2255# Call List
    *#232337# Bluetooth MAC Adress
    *#5282837# Java Version
    #*4773# Incremental Redundancy
    #*7752# 8 PSK uplink capability bit
    #*7785# Reset wakeup & RTK timer cariables/variables
    #*1200# ????
    #*7200# Tone Generator Mute
    #*3888# BLUETOOTH Test mode
    #*#8999*324# ??
    #*7828# Task screen
    #*5111# ??
    #*#8377466# S/W Version & H/W Version
    #*2562# Restarts Phone
    #*2565# No Blocking? General Defense.
    #*3353# General Defense, Code Erased.
    #*3837# Phone Hangs on White screen
    #*3849# Restarts Phone
    #*3851# Restarts Phone
    #*3876# Restarts Phone
    #*7222# Operation Typ: (Class C GSM)
    #*7224# !!! ERROR !!!
    #*7252# Operation Typ: (Class B GPRS)
    #*7271# CMD: (Not Available)
    #*7274# CMD: (Not Available)
    #*7337# Restarts Phone (Resets Wap Settings)
    #*2787# CRTP ON/OFF
    #*2886# AutoAnswer ON/OFF
    #*3737# L1 AFC
    #*5133# L1 HO Data
    #*7288# GPRS Detached/Attached
    #*7287# GPRS Attached
    #*7666# White Screen
    #*7693# Sleep Deactivate/Activate
    #*7284# L1 HO Data
    #*2256# Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
    #*2286# Databattery
    #*2527# GPRS switching set to (Class 4, 8, 9, 10)
    #*2679# Copycat feature Activa/Deactivate
    #*3940# External looptest 9600 bps
    #*4263# Handsfree mode Activate/Deactivate
    #*4700# Please use function 2637
    #*7352# BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
    #*2558# Time ON
    #*3370# Same as 4700
    #*3941# External looptest 115200 bps
    #*5176# L1 Sleep
    #*7462# SIM Phase
    #*7983# Voltage/Freq
    #*7986# Voltage
    #*8466# Old Time
    #*2255# Call Failed
    #*5187# L1C2G trace Activate/Deactivate
    #*5376# DELETE ALL SMS!!!!
    #*6837# Official Software Version: (0003000016000702)
    #*7524# KCGPRS: (FF FF FF FF FF FF FF FF 07)
    #*7562# LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
    #*2337# Permanent Registration Beep
    #*2474# Charging Duration
    #*2834# Audio Path (Handsfree)
    #*3270# DCS Support Activate/Deactivate
    #*3282# Data Activate/Deactivate
    #*3476# EGSM Activate/Deactivate
    #*3676# FORMAT FLASH VOLUME!!!
    #*4760# GSM Activate/Deactivate
    #*4864# White Screen
    #*5171# L1P1
    #*5172# L1P2
    #*5173# L1P3
    #*7326# Accessory
    #*7683# Sleep variable
    #*8465# Time in L1
    #*2252# Current CAL
    #*2836# AVDDSS Management Activate/Deactivate
    #*3877# Dump of SPY trace
    #*7728# RSAV
    #*2677# Same as 4700
    #*3797# Blinks 3D030300 in RED
    #*3728# Time 2 Decod
    #*3725# B4 last off
    #*7372# Resetting the time to DPB variables
    #*7732# Packet flow context bit Activate/Deactivate
    #*6833# New uplink establishment Activate/Deactivate
    #*3273# EGPRS multislot (Class 4, 8, 9, 10)
    #*7722# RLC bitmap compression Activate/Deactivate
    #*2351# Blinks 1347E201 in RED
    #*4472# Hysteresis of serving cell: 3 dB
    #*2775# Switch to 2 inner speaker
    #*9270# Force WBS
    #*7878# FirstStartup (0=NO, 1=YES)
    #*3757# DSL UART speed set to (LOW, HIGH)
    #*8726# Switches USBACM to Normal
    #*8724# Switches USBACM to Generator mode
    #*8727# Switches USBACM to Slink mode
    #*8725# Switches USBACM to Loop-back mode
    #*3838# Blinks 3D030300 in RED
    #*2077# GPRS Switch
    #*2027# GPRS Switch
    #*0227# GPRS Switch
    #*0277# GPRS Switch
    #*22671# AMR REC START
    #*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
    #*22673# Pause REC
    #*22674# Resume REC
    #*22675# AMR Playback
    #*22676# AMR Stop Play
    #*22677# Pause Play
    #*22678# Resume Play
    #*77261# PCM Rec Req
    #*77262# Stop PCM Rec
    #*77263# PCM Playback
    #*77264# PCM Stop Play
    #*2872# CNT
    *#8999*283# ???
    #*22679# AMR Get Time
    *288666# ???
    *2886633# ???
    *#8999*364# Watchdog ON/OFF
    #*8370# Tfs4.0 Test 0
    #*8371# Tfs4.0 Test 1
    #*8372# Tfs4.0 Test 2
    #*8373# Tfs4.0 Test 3
    #*8374# Tfs4.0 Test 4
    #*8375# Tfs4.0 Test 5
    #*8376# Tfs4.0 Test 6
    #*8377# Tfs4.0 Test 7
    #*8378# Tfs4.0 Test 8
    #*8379# Tfs4.0 Test 9
    #837837# error=...
    #*36245# Turns Email TestMenu on.
    *2767*22236245# Email EPP set (....)!
    *2767*837836245# Email Test Account!
    *2767*29536245# Email Test2 Account!
    *2767*036245# Email EPP reset!
    *2767*136245# Email EPP set (1)!
    *2767*736245# Email EPP set (7)!
    *2767*3036245# Email...
    *2767*3136245# Email...
    *2767*3336245# Email...
    *2767*3436245# Email...
    *2767*3936245# Email...
    *2767*4136245# Email...
    *2767*4336245# Email...
    *2767*4436245# Email...
    *2767*4536245# Email...
    *2767*4636245# Email...
    *2767*4936245# Email...
    *2767*6036245# Email...
    *2767*6136245# Email...
    *2767*6236245# Email...
    *2767*6336245# Email...
    *2767*6536245# Email...
    *2767*6636245# Email...
    *2767*8636245# Email...
    *2767*85236245# Email...
    *2767*3855# = E2P Full Reset
    *2767*2878# = E2P Custom Reset
    *2767*927# = E2P Wap Reset
    *2767*226372# = E2P Camera Reset
    *2767*688# Reset Mobile TV
    #7263867# = RAM Dump (On or Off)
    *2767*49927# = Germany WAP Settings
    *2767*44927# = UK WAP Settings
    *2767*31927# = Netherlands WAP Settings
    *2767*420927# = Czech WAP Settings
    *2767*43927# = Austria WAP Settings
    *2767*39927# = Italy WAP Settings
    *2767*33927# = France WAP Settings
    *2767*351927# = Portugal WAP Settings
    *2767*34927# = Spain WAP Settings
    *2767*46927# = Sweden WAP Settings
    *2767*380927# = Ukraine WAP Settings
    *2767*7927# = Russia WAP Settings
    *2767*30927# = GREECE WAP Settings
    *2767*73738927# = WAP Settings Reset
    *2767*49667# = Germany MMS Settings
    *2767*44667# = UK MMS Settings
    *2767*31667# = Netherlands MMS Settings
    *2767*420667# = Czech MMS Settings
    *2767*43667# = Austria MMS Settings
    *2767*39667# = Italy MMS Settings
    *2767*33667# = France MMS Settings
    *2767*351667# = Portugal MMS Settings
    *2767*34667# = Spain MMS Settings
    *2767*46667# = Sweden MMS Settings
    *2767*380667# = Ukraine MMS Settings
    *2767*7667#. = Russia MMS Settings
    *2767*30667# = GREECE MMS Settings
    *#7465625# = Check the locks
    *7465625*638*Code# = Enables Network lock
    #7465625*638*Code# = Disables Network lock
    *7465625*782*Code# = Enables Subset lock
    #7465625*782*Code# = Disables Subset lock
    *7465625*77*Code# = Enables SP lock
    #7465625*77*Code# = Disables SP lock
    *7465625*27*Code# = Enables CP lock
    #7465625*27*Code# = Disables CP lock
    *7465625*746*Code# = Enables SIM lock
    #7465625*746*Code# = Disables SIM lock
    *7465625*228# = Activa lock ON
    #7465625*228# = Activa lock OFF
    *7465625*28638# = Auto Network lock ON
    #7465625*28638# = Auto Network lock OFF
    *7465625*28782# = Auto subset lock ON
    #7465625*28782# = Auto subset lock OFF
    *7465625*2877# = Auto SP lock ON
    #7465625*2877# = Auto SP lock OFF
    *7465625*2827# = Auto CP lock ON
    #7465625*2827# = Auto CP lock OFF
    *7465625*28746# = Auto SIM lock ON
    #7465625*28746# = Auto SIM lock OFF
I need to format my phone
Posted on Oct 23, 2010
There is no service on my samsung mobile E250 how do i get the service and the password to reset is missed ?
Posted on Sep 10, 2009
Samsung e250i carema is lock and i want to formet the mobile so pl any bady know formet number so that tell me.
Posted on Dec 28, 2009
Please i need your help i want to format my phone
Posted on Dec 14, 2011
I lock my phone please send me the code of samsung e 250
Posted on Mar 13, 2011
  • Vells Jun 13, 2011
    My phone dening playing other tracks plz help me
Games for e250
check the game format,usually samsung support jar file
Aug 08, 2009 | Samsung SGH-E900 Cellular Phone
Sir i want pc suite for my samsung e250
visit samsung mobile web site and download
Jul 02, 2009 | O2 Samsung SGH-E250 Cellular Phone
''install error'' when im downloading games on my e250 via wap
If it's a samsung e250 you have to make sure the games are 160x120, and some games don't work on the phone because they weren't made for the phone. You can try some games from here (it's free and legal) http://www.mobilerated.com/samsung-sgh-e250-games.html but they don't have games made by companies, you can try rapidshare for full version of the game free but it is illigal. If you buy a game make sure it is 160x120 and can run on samsungs. Hope this helps =D
May 25, 2009 | O2 Samsung SGH-E250 Cellular Phone
I Want to install media player & theme in my samsung sgh-E250 mobile phone plz tell me how to install that stepwise, plz..plz..plz helf me
Just visit http:/www.getjar.com
Here you can get everything required by you for your phone. Just download and install.
Dont forget to rate this, please.
Apr 23, 2009 | O2 Samsung SGH-E250 Cellular Phone
Mobiles
what softwares you need in your mobiles
Mar 09, 2009 | O2 Samsung SGH-E250 Cellular Phone
My mem card can't detected
Most likely you got dirt or corrosion on the terminal, try to spray terminal cleaner
Oct 10, 2008 | Samsung SGH-E900 Cellular Phone
E250
you can format the .wma files to .mp3 without losing your files
May 18, 2008 | Samsung SGH-E900 Cellular Phone
Lands Phones Logo
8,558 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
