Question about Microsoft Office Professional 2007 Full Version for PC
I need to find the triple (?) root of a number (sim to sqr rt)
Trying to find a formula that finds the triple root (not sure of name) of a number. Similar to square root of a number. Using excel 2003. Thanks
  • processor803 Nov 18, 2008
    Thanks, I was loking all over excel help for this.
  • 45 Answers
=number^(1/3)
Posted on Nov 18, 2008
Sslc maths
What follows is true for CONVEX polygons.
Let n be the number of sides of a convex polygon, and let n be greater than or equal to 4, then
The number of diagonals is given by n*(n-3)/2
Using this rule, write n*(n-3)/2=20. Clear the fraction, open brackets. You end up with n^2-3n-40=0.
Factor the polynomial or use the formulas for the quadratic equation to find the roots as n=-5 or n=8. Discard the negative root because n must be positive.
Oct 05, 2013 | Computers & Internet
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Why do incoming calls on my samsung galaxy pocket come up as unknown?
If you imported all your sim contacts &google contacts the phone might now hav some numbers duplicated or even tripled and then does not know which name to display when you receive a call from a number listed on multiple accounts. Go to your contacts & check all the boxes to display all possible contacts you hav- sim, google, phone, sd card, etc. Go through the list &try to take out all the numbers listed under more than one contact name! Even if it is the same name! It takes some time to sort out if you hav a lot of contacts, but that fixed my problem! Good luck!
Jun 18, 2013 | Samsung Galaxy Pocket
How do you simplify surds
Most calculators (except perhaps the TI89) can't do this sort of simplification, so you will need to factorise the number yourself to get sqr(200) = sqr(2*100) = sqr(2) * sqr(100) = sqr(2) * 10.
May 29, 2012 | Casio FX-7400G Plus Calculator
I cant find my serial number for my sims triple deluxe game can u help me find it?
If you are unable to locate your serial number for the game you have a couple of options. The are outlined below. I wrote a tech article which goes over these options in some more detail. Click the link below to read my tech article.
How to obtain serial key
Outline
-Contact Sims tech support and see if they can provide a new one. Click here for the support page.
-Purchase a new copy of the game thus getting a new serial number.
-Bypass the game activation using a crack program or files.
Let me know if you have any questions.
Regards,
G33k
Aug 05, 2011 | EA - Electronic Arts The Sims Triple...
How do you find out how long it would take to triple an amount at 6% interest, compounded continuously?
Solve the formula e^(rt) = 3 , where r=0.06 per time period
(see http://en.wikipedia.org/wiki/Compound_interest#Continuous_compounding for details)
Taking the logarithm of both sides and rearranging gives: t = ln(3)/0.06 = 18.31 time periods. The logarithm function is a shifted function on the 2 button on the 10bii calculator.
May 09, 2011 | HP 10bII Calculator
How i use underroot inexel farmula
Hey!
I'm not sure what do you mean by "underroot", but if it's the square root that you need, the formula is as follows:
=SQRT(A1)
and also:
=A1^(1/2) - the square root
=A1^(1/3) - the cube root
etc...
For more info, look here...
Regards,
Pelu.
Feb 09, 2011 | Business Industrial Network Free MS Excel...
To print the square root of all the numbers from 1 to 25
#include<stdio.h>
#include<conio.h>
#include<math.h>
void main()
int a;
printf("enter no");
scanf("%d",&n);
printf("sqr(n.0.5)");
Jan 11, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Analytic geometry
assuming the question is what is the circle equation?
and if (-2,2) is the center of the circle
the equation should look like this: (x+2)^2+(Y-2)^2=R^2
And now only R is needed.
given 2x-5y+4=0 equation of line perpendicular
we can rearange the equation to be y=(2x+4)/5
from that we can see that the slope of the line is 2/5
And from the fact of perpendicular line we can say that the slope
of the radius line is -2/5.
The motivation now is to calculate the distance between the center of the circle to the cross point of the radius with the line perpendicular
For that we would calculate the radius line equation and compare it to the equation of line perpendicular
As mentioned earlier the slope of the radious line is -2/5.
So the equation is y=-2/5x+b and b can be calculated by using the center of the circle coordinates
2= - (2/5)*(-2)+b ------> b=2-4/5=1.2
radius equation is y=-(2/5)x+1.2
Now the cross point is calculated by comparing the equations:
-(2/5)x+1.2=(2x+4)/5 --> -2x+6=2x+4 --> 4x=2 --> x=1/2 --> y=1
So the cross point is (1/2,1).
The distance between the points is calculated by the following
Formula:
R=SQR(((1/2)-(-2))^2+(2-1)^2)=SQR(2.5^2+1^2)=SQR(6.25+1)=
SQR(7.25)
Therefore the circle eq is (x+2)^2+(Y-2)^2=7.25
Oct 26, 2008 | Casio FX-115ES Scientific Calculator
EXCEL FORMULA
try using the formula "sumif". It allows you to sum by category/name. Good luck! D.
Sep 12, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
734 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
