Question about Thermaltake (LANFIRE) ATX Mid-Tower Case
Connecing fans so i can control speed
How do i connect up the fans any way i have tried i just get them working but not able to control the speed of them with the control nobs on the fron of the case????
  • 49 Answers
A lot of the times the way you hook up the fans to the power supply can determine which powe setting they are on. 3 pin or 4 pin connectors? Do the y have switches on them? Some fans have auto, hi and low settings on them.
Some fans will only run at one speed no matter what, make sure you have adjustable fans. YOu can go to zipzoomfly.com or newegg.com and do a search for case fans and find some that suite what you need. YOu can replace fan real cheap nowadays.
Also check to see i you have eom software that came with your case that you may need for your mobo to be able to adjust your fans.
Posted on Nov 30, 2008
My monitur for my dvr keep saying no singnal
Check its VGA connecing cable for connection firmness. Re-connect it once, and check. Try an other cable, if it do not help you. Gopakumar Gopalan Google
May 16, 2014 | Televison & Video
Hi, im using a motherboard asus m4a88td-m and i cant control my fan speed(cpu fan and chassis fan) in any way.... i tried the asus motherbord software it doesnt work, i try settings in the bios(cool and...
You may not have the correct type of fan for this to work. Typically, you need a three or four pin fan (you will see three or four wires on the plug) for fan speed control to work correctly. If you only have two wires, your fans do not have speed control functionality.
You can also have another issue. If you do have a three or four ping fan, you may not have it connected to the correct fan headers on the motherboard for it to work correctly, or you may have it connected to an external fan controller.
May 05, 2011 | Computers & Internet
What controls the speed of a range hood fan? , only when i push the hi button or the low speed button, the hi speed button only works. its a old model built in 1960 , can't find the model number ...
You will need to check inside the button contacts to identify if the control of current is by a series resistor or by the coil winding.
Since the high speed is working it is possible that the series resistor coil is open.So check for loss of contact continuity in the switch, if not you can use the present model of electronic fan controllers to give you a variable fan control. This can be connected to the main hi speed connection.
Tip: Identify the wattage and buy the regulator according to the specs.(42 inch type)
Dec 18, 2010 | Kitchen Ranges
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
The fan speed controller box is not working,that mean the radiator cooling fan is not working to .
does the fan work when connected directly to power? is there power present at the fan connector, what about at the fan speed controller?
Oct 31, 2009 | Gigabyte 3D Galaxy II CPU Water Cooling...
Fan control only works on speed 4
The fan may have to be replaced. Do check the back of your control switch to make sure all vacuum hoses are connected.
Aug 02, 2009 | 2004 GMC Canyon
Antec fans connected to akasa fan controller, Speed doesn't change
Sounds like a problem with your fan controller. The controller is simply controlling the voltage applied to the fan to adjust the speed. Have you tried a fan without a speed control built in?
May 09, 2009 | Akasa Fan Speed Control Fan Controllers
Climate control varible speed fan not working
According to the schematics on your vehicle, it has a "Blower motor control processor" either built in to your controls, or in line between your controls and blower motor. Yo may get real lucky and find some dirty connections in that area, and get away with cleaning & re-connecting, but I wouldn't get my hopes up too high. You may end up replacing the processor, as it regulates fan/blower speed.
Feb 16, 2009 | 2004 Buick LeSabre
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Jan 03, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
Core fan Abnormal - Fan Speed 0 rpm - System slowdown
Well, since you connected your fan directly to the power supply, you are not getting any feedback thru the graphics card interface. This doesn't mean there is a problem since your fan is running full speed all the time, it is actually better and you should be able to see a difference on the GPU temperature.
If the GPU temperature is still too high and the fan is running at full speed, did you apply a thin coat of thermal paste on the heatsink? if not, there is your problem.
Now just to be clear did you connect the fan to the power supply or to a spare motherboard connector. If you connected to your motherboard, you need to go in the BIOS and change some settings regarding the fan speed (let me know if this is the case and I'll help you further about that.)
Alex J.
Feb 20, 2008 | Abit RX600PRO-GURU RADEON X600 PRO GURU,...
Thermaltake (LANFIRE) ATX Mid-Tower Case Logo
177 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
