Question about Cell Phones
My bluetooth haeadset disconnect its self from my handset.
It makes me miss calls .
  • 13 Answers
Well it could be one of two things. Either there is something wrong with your phone holding the connection to your bluetooth or there is something wrong with the bt device. Test this by pairing up the bluetooth earpiece with a different device. What kind of phone are you using to pair the device up with??
Posted on Nov 18, 2008
How to pair my sprint slx-800 to my android phone
You should search for this topic and answers, First.
Try 0000 that's the default for all bluetooth accessories.
If that doesn't work, here is generic instructions:
Paring a Bluetooth Handset with Android phone:
Instructions:
Now that you have your headset in pairing mode, proceed to pair it with your phone:
From the home screen, press the Menu key and then select Settings.
Tap the "Bluetooth" toggle to ON.
Tap Bluetooth to scan for devices.
NOTE: You will automatically be connected to an available saved device when Bluetooth is turned on.
Tap one to connect.
NOTE: A security code may be required. (Try 0000)
The Bluetooth connected icon will be displayed in the notification bar, and the device will now be labeled as Connected.
Place calls using the Bluetooth headset
Ensure the Bluetooth headset is paired with the handset.
Place the Bluetooth headset over your ear.
Dial the desired the phone number on your phone, and then tap Call.
Receive calls using the Bluetooth headset
Press the Call button on the Bluetooth headset when a call is received.
Aug 20, 2015 | Sprint Cell Phones
User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
Plantronics 500A/510S User's Guide
Good luck from Headsets Direct!
Apr 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I have a plantronics bluetooth. I'm not sure of the model. After I talk on it sometimes the bluetooth will peep and seems to disconnect from my voyage phone but the bluetooth stays on. I hit the call...
Install Nokia Phoniex in your computer and attach handset.
1. detect device 2. click on device information and print it. you got answer
Jul 01, 2010 | Cell Phones
I cant hear any phone calls without using earphone on my motorola w220 handset.& I cant see anything on my screen.
Did you make sure you disconnected it under bluetooth settings first? Because the phone might still be transferring the sounds to the earphone.
Aug 03, 2009 | Motorola Cell Phones
Problem re-I-MATE SP5M
hi thanks for using fixya!!
Try to remove the one you have installed, the bluetooth handset, and then try to make a call. If you are able to make a call. Perhaps, the device you have installed is not compatible with your Imate.
Jul 07, 2009 | i-mate SP5 Smartphone
Handset constantly display missed calls
you have to clear them. it will show missed call on all the ones you did not answer the call on.
Mar 09, 2009 | Panasonic KX-TG1033S Cordless Phone
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth disconnects after 5 minutes
I know this sounds silly, but try having your cell phone more than a couple feet away from the base of the DECT phone. Bluetooth can have issues when they are really close together. I have mine setting about 6ft away without problems.
Jan 21, 2009 | GE Lands Phones
Razr v3 bluetooth
all i can say by reading your issue is that , it would have to do with you being on the cycle and moving . but i will check on this for you.
Sep 19, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
96 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
