Question about HP Office Equipment & Supplies
My c6300 printer will not print from the photo tray
SOURCE: Mac Leopard OS: Can't print from photo tray
Here's the trick. It took me an hour to figure this puzzle out myself. DO NOT select the Print icon at the bottom of iPhoto. Do NOT select Print from the File menu. DO select EXPORT from the File menu. Select the HP Photosmart Mac tab Select HP Photosmart Print.app from the app selector. Click the Export button. HP Photosmart Print.app will load with a new print dialog box. Make all necessary selections. This is where you can select the Photo Tray as the tray for the printer to take paper from. This solved MY problem! Let us know if this helps you!
Randy
Posted on May 23, 2008
  • 3 Answers
SOURCE: Printing from the photo tray
I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
Posted on Dec 04, 2008
MUKHTAR
  • 2022 Answers
SOURCE: HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Sep 08, 2009
SOURCE: Unable to print to photo tray
FIXED BY ADJUSTING PAPER SIZE
Posted on Sep 21, 2009
SOURCE: I want to print a photo using the photo paper
I had to adjust the advanced print settings on my computer.
Posted on Oct 03, 2009
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
I can't get my hp photosmart printer to print photos from my hard drive onto the photo paper. It will print the photos from the paper tray.
You have to shift the paper tray. Click on start, click on printer/faxes right click click on your printer, click on printer preferences, select photo printing borderless. This shifts your paper tray to photo paper.
Dec 20, 2010 | Computers & Internet
How do you choose the tray to print from. Photo
Yes there is.
You can see on the printer panel, there is a button for "photo tray".
If the light is "on" it means the button has been pressed and the printer will try to engage the photo tray in the next print job.
If the light is "off" it means the printer will ignore the photo tray.
Cheers,
Ed
Nov 07, 2009 | HP Photosmart D7360 All-In-One InkJet...
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
My photosmart 7150 prints half a page(vertical half) ! It worked fine before this. Help! thanks
Ok, I was having this same problem and the solution for me appears to lay in the fact that the "photo tray" was pushed in, signaling to the printer that it should print to the size specifications of a photo (approximately half the width of a standard letter page). I should also mention that with my problem, the printer would hang at every single print job--presumably to wait for you to input your photo paper--and that executing this fix solved the problem.
To fix this, I followed these instructions: SOLUTION:Follow the steps below to correct the issue:
  1. Disconnect power to the printer.
  2. Remove all photo paper from the Photo Tray.
  3. Push the Photo Tray completely into the printer.
  4. Snap the Photo Tray out (towards you) sharply.
  5. Reconnect power to the printer.
  6. Print a self-test on 8.5 X 10 paper.
  7. Engage the Photo Tray.
  8. From the Printer Toolbox, select Calibrate the Photo Tray .
Sep 26, 2009 | HP PhotoSmart 7150 InkJet Printer
Will not print photo from main tray
The printer will automatically select the "Print Quality" Media based on its driver settings or the device settings.
You will need to access the properties of your printers software to assure that you have selected photo paper for the tray you wish.
Depending on which model of printer your using, you may have to access the Settings/Options/Page Setup/Tray Setup Menu. Consult your Owners Manual for settings these Tray options. Make sure you have set the tray you wish for Photo Paper (or comparable quality option)
Let us know
Good luck
Apr 14, 2009 | HP Media Center m7250n (ED842AA) PC...
My printer c5280 keeps saying please reinsert or lower photo tray
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
Nov 01, 2008 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
60 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
