Question about Yahoo Messenger
Signing on to yahoo messenger 900-2034.
Can you please tell me why my yahoo messenger will not open immediately. It comes up with try again new user etc etc and was at first listing the number 81003005. I have uninstalled and reinstalled many times. signed on as new user (it works) but I want my bella0407 user name back working correctly. It takes hrs and hrs and hrs to open up but if I persevere with it long enought (hrs) it will open. I can use other computer and open it with no problem. Can you please give me a solution to this. Regards Liz
  • 57 Answers
Try uninstall again the yahoo messenger select complete uninstall, remove also backup data if system ask and after uninstall complete go to C:\Program Files\Yahoo! folder and delete Messenger folder, remove also in recycle bin, restart your computer and install yahoo messenger again. I suggest to install the Yahoo Messenger Full Standalone Installer, you find this at google search.
Posted on Nov 22, 2008
Yahoo messenger is not open
Hello rasirajini
your yahoo messenger might be old or new version available download a new copy of yahoo messenger and log in again this will sure help you
Click here to Download
Regards
Manish
Apr 08, 2010 | Yahoo Messenger
I am unable to sign in to yahoo messenger but i can sign in to other yahoo functions like mail and webmessenger. the only problem is, is with the messenger. I have tried using a different yahoo id but i...
Install older version of yahoo messenger..
And let me tell your one thing that, when to try to login to your yahoo account on yahoo messenger, your internet connection must be responding. This you can ensure by keeping your server busy(opening websites).
The problem you are telling might be caused when you are trying to login to yahoo account through yahoo messenger and yahoo mail.
I recommend you that you open yahoo account through yahoo mail(only if you are unable to sign in to yahoo account through yahoo messenger.)
yahoo mail now-a-days is providing yahoo chat service when you sign in your yahoo account on yahoo mail.
at left side of your mail box you can see yahoo mini messenger.
THANK YOU for contacting Fixya.com
Oct 18, 2009 | Yahoo Messenger
I can't open ym its locked when i sign in
If you've received an account locked error message when trying to sign into Yahoo! Messenger you should find this a simple issue to fix.
Please sign in on the Yahoo! Sign In page.
Once you've signed in to your account, try Yahoo! Messenger again. If you continue to receive the error message or have some other issue, please contact Yahoo! Messenger Customer Care, using the link below:
http://us.lrd.yahoo.com/_ylt=Avux44hFQnrIC2Ug5svxHZKHDCl4/SIG=1105qtnvf/**http%3A//messenger.yahoo.com/
Oct 08, 2009 | Yahoo Messenger
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
Cannot sign in yahoo messenger
It may have 2 problems and 2 solutions:-
Firstly, this error occurs when your connection preferences are notproperly set. I'm not talking about your Yahoo! ID and Password here,but you may need to adjust certain features depending on what networkyou're on. Let's says for example, if a firewall protects your network,it may block yahoo messenger when it tries to connect to the server.You need to change your connection settings, click the Messenger menuin yahoo messenger and select Connection Preferences. Select FirewallWith No Proxies. Select your Internet Connection type from thepull-down menu at the bottom and enter your Home Country if theseoptions aren’t grayed out. Click OK and login again using the newsettings.If this option doesn’t work, click Connection Preferences inYahoo! Messenger again and select No Network Detection. Try to loginagain using the new settings. In some instances, you may need toprovide yahoo messenger with the IP address of your firewall or proxyserver (you can get this information from your network administrator orfrom your Internet service provider). Click Messenger and selectConnection Preferences again. Select Use Proxies. Enable either theHTTP Proxy or the SOCKS Proxy as needed and provide the proper address.Click OK and login again using the new settings.
Secondly, if you are using IM9 there are sign in problems. This is whatyahoo has to say.Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issuesthat have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix thatproblem. Even if you were experiencing a different kind of sign-inissue, I recommend installing this latest version.
Hope it can be helpful!
If you satisfied with this information, please do support me...
Thank You!
Jun 07, 2009 | Yahoo Messenger
I cannot sign in it tells me try aagin (81003004)
change ur yahoo version..try to use yahoo 9 or 9.1..evrything will b just alright..
May 12, 2009 | Yahoo Messenger
I cannot sign into yahoo messenger
The problem I have with not being able to sign into yahoo messenger is that I get an error message with number that are 81003004. It says try again...new user and sign in problems. This has been going on for many months now and I have removed yahoo from add and remove and downloaded yahoo messenger many many times. I really like yahoo and essepically my radio station I created and miss some of my friends I cannot contact any more. Please help me resolve this problem. I can sign into my home page with correct password with no problem but not yahoo messenger. Like I said the error message I get is 81003004 that is showing up on my yahoo messenger IM log in. Thank You for your assistance. chickiechackey@yahoo.com
Mar 12, 2009 | Computers & Internet
Problem in signing in to yahoo messenger
well if you are in hurry you can use the link.
http://webmessenger.yahoo.com/
just enter your login id and password..
To make work your yahoo messenger go to control panel > Double click Add Remove Programs and uninstall yahoo..
when it is uninstall .restart your computer and install it again...and go to preference of yahoo messenger and make default changes ..
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Mar 13, 2008 | Computers & Internet
Yahoo Messenger Logo
440 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
