Question about Protron PLTV-32 Television
My PLTV 3250 keeps switching from tv to dtv on its own!
I have reset it and it will still switch from tv to dtv at least three or four times an hour. i am able to switch it back but it is annoying. when watching a DVD it will switch from AV 1 to AV2 so i know its not my satellite. if you have any suggestions please help!
  • Anonymous Apr 03, 2009
    i just got this t.v. from my friend for free because it started switching from av1 to av2. I'm gonna go try unplugging and turning it back on manually to see what happens. hopefully it works??
I had the same problem and called the company. They suggested this solution and to my amazement... it worked! Turn off the TV manually (don't use the remote). Unplud the TV from power supply. Wait 1/2 hour. Then replug and turn it on manually. It should take care of it by resetting to factory settings. You will have to redo any color, hue, brightness, etc adjustments. Sherri
Posted on Dec 14, 2006
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 13, 2010 | Protron PLTV-32 Television
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is...
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jul 12, 2010 | Protron PLTV-32 Television
Protron pltv 3250 power cord
It is the same power cord as used for your PC, NEMA5-15P to IEC C13.
This TV has known problem with power supply, so keep an eye on it.
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 18, 2010 | Protron PLTV3250 32 in. LCD Television
PLTV 3250 no power
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, common problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
Apr 26, 2010 | Spectroniq PLTV3250 32 in. LCD TV
My tv just died no power on my protron pltv 3250 power is at the plug in box but tv shows nothing.
Hello Bkobert, hi, before going through the set, kindly check first the following.
1. Check your mains AC line.
2. Check your TV plug cable, they may be loose.
3. Also check if the plug has a user fuse.
If ok, then there is a problem with your TV's switching power supply, a fuse on the board may be open, or loose wiring inside.
The symptoms may go to the extreme, like a faulty switching regulator section, which include the power transistor, IC regulatorm dried up capacitors, and low value resistor.
You may also choose to replace the entire board. thats all. keep me posted
Mar 02, 2010 | Protron PLTV-32 Television
Tv has no power - Protron PLTV 3250
Look at the othewr posts for Protron PLTV - 3250. You need a power supply.
Aug 16, 2009 | Protron PLTV3250 32 in. LCD Television
After the DTV switch, should I be placing the cable cord into the dtv output to receive all the DTV channels? Protron PLTV 3250 is the set I have and it doesn't seem to get the DTV channels like my other...
Your question is confusing. If you have cable, you don't need a DTV converter box.
If your cable company has switched to digital cable, they will provide you a box, and the cable should go from the wall into the box, then into your TV.
If you don't have cable but instead rely on an antenna, then the wire will go from the antenna into the DTV box, then from the DTV box into the back of the TV. If you're using a regular coaxial cable to go from the DTV box into the television, the TV should be set to channel 3. If you're using the red-yellow-white RCA wires between the DTV box and the television, the TV must be tuned to "Aux," "Line In," "Input Select," or whatever it's labeled on your particular set.
Jun 12, 2009 | Protron PLTV-3750 Television
Digital signal
hi my name is mark, if you are already hooked to dish network, there is nothing you have to do. you are ready fotr the dtv change over june 12 09
Aug 17, 2008 | Protron PLTV-32 Television
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
147 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
