Question about Whirlpool Refrigerators
Whrilpool ART 745 American Fridge Freezer Can't get new filter to go right into housing. Tried efitting the old one and even with the "O" rings removed it still stops 10-12mm (3/8-1/2") short of correct position. Side lugs of cartridge are correctly orientated at 3 and 9 o'clock.
Sea Breeze
  • 4655 Answers
SOURCE: ge eterna series fridge side not working
Could you look inside the freezer compartment and after unplugged remove the panel to see if ice is blocking the vent to fresh food compartment. If there is ice it could be something is not working with the defrost cycle. Your refrigerator has a control board that handles these processes but other factors can cause ice buildup in vent. Thanks, Sea Breeze
Posted on Mar 26, 2009
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
  • 1218 Answers
SOURCE: Ice Maker stopped working -- new fridge 3 months old.
Good day,
Icing could be one problem. The first thing to test is the water supply to the machine. Shut the house off at the meter. Remove the line from the water valve at the machine. Insert the line into a bucket while someone else turns on the water at the meter for a 15 second count. It should come out forcefully, not weak or just dribbling.
If it's bad, then the line and the fittings where it connects to the house supply should be inspected, and cleaned or replaced as needed.
If it is O.K. and the machine is under one year of age, it is under warranty and you should call your selling dealer for a free service call.
Posted on Jun 30, 2010
Testimonial: "Thanks! Will try that out. I also grabbed some insight from other solutions posted for others, will try pouring some water into the ice maker and see if it processes that. That will tell me for sure if it is the entire maker or just the water supply that may be bad. "
aasc
  • 1606 Answers
SOURCE: Ge side by side I have to keep defrosting the
Do this when the refrig starts to warm up . Don't defrost before this test .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Jul 18, 2010
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
our problem was fridge door alarm ,no cooling ,light out ,Freezer ok. Turned out to be the fridge side of the fridge/freezer door switch . Removing the double switch (it's a press fit) enables the fridge fan to work while waiting replacement. Replaced with new double switch now we have a light too.
Posted on Jan 10, 2011
My Daewoo American fridge freezer is not making ice in the ice compartment and food have started to defrost but you can hear the fridge freezer working
How old is the fridge? If it is old I suspect the compressor is not functioning as it should. Things to check before calling the repairman or buying a new one: The thermostat setting. Be sure there are no air leaks around the door seals.
Jan 10, 2018 | Daewoo Refrigerators
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Fridge seems to run too frequently
How old is the fridge? Newer units will run more frequently and make "running" noises.
Apr 30, 2012 | Kenmore Refrigerators
We've got a GE American Fridge Freezer. 12 years
time to get a new freezer. check the floor under the freezer for coolant leakage, if none the compressor is ready to deep 6...
Nov 07, 2009 | General Electric Chest Freezer FCM5SU
Location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Jul 22, 2009 | Refrigerators
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Whirlpool American Fridge Freezer
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
American fridge freezer - sansumg rsh1dtmh
this samsung fridge freezer diy channel may help ckick here
also check this video ....http://www.youtube.com/profile?feature=iv&user=SamsungFridgeFreezer&annotation_id=annotation_526429
Dec 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Zanussi frost free fridge freezer
if problem happens every fewhours it is possibly the defrost element
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Refrigerators Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
