Question about Shuttle AV40 Motherboard
Front panel wiring connection to av40v12 motherboard
Hi, can you advise on the layout for coonection the front panel wires to the pins on the motherboard?
Thanks
Dave
  • Anonymous Dec 09, 2008
    can someone post wiring order for front connectors power ,hdd reset.thanks in advance , already try shuttle site with no luck.
  • 541 Answers
Wot make is your motherboard
Posted on Nov 18, 2008
How to connect front panel to acer power s290 motherboard
http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
Nov 01, 2012 | Acer Power S290 PC Desktop
I need a wire diagram for a Gateway Mother board MCP61PM-GM
Carole,
The front of the computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Would this be what you require, or more extensive?
From a fellow FixYa expert,
http://www.fixya.com/support/t614458-hp_mcp61pm_hm_motherboard_diagram
I know it states MCP61PM-HM
The 10-pin ( actually) Front Panel header, is the same across the board, for ECS motherboards.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.playtool.com/pages/psuconnectors/connectors.html
Oct 09, 2012 | Computers & Internet
I am looking for MCP61PM-HM (Nettle) 9 pin front panel power header diagram
This motherboard Adam?
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
Can't help you.
OH, I'm just KIDDING!
The area of pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
On the motherboard the Front Panel header is marked as PANEL1.
Scroll the page down, until you come to Motherboard layout.
Click on the + sign to the left of it.
Shows an illustration of the motherboard.
Bottom/Right corner is PANEL1. The black rectangle that is sitting vertically, in the motherboard photo.
Motherboard installed in computer case, the Front Panel header is two columns of contact pins.
FOUR on the Right side, FIVE on the Left side.
I don't know the actual numbering of the pins, so I'm going to number them myself;
Starting on the Left side at the Top, going down,
Pins 1, 3, 5, 7, and 9.
Starting on the Right side at the Top, going down,
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. If not, do not connect to them.
C) Pin 9 is N/C. Not Connected. It was a +5 Volt power for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
E) Pins 6 and 8 are for the Power On switch.
F) NO pin 10, just a blank spot.
How to find out what wires are what, in that Front Panel harness connector?
Follow the wires from the connector, up to the Front Panel.
Front Panel removed it is easier to see where the wires go.
You can follow the color code of the wires, and see which twisted pair go up to the Power On switch.
You can also see which ones go to the Power On LED.
(Light Emitting Diode, so it is a light)
Reset switch, (IF there is one), same thing.
The only pair of wires that will be left is the HDD LED wires.
HarDDrive activity LED.
The 9-pin plug will have to be CAREFULLY cut apart. Separate the wires, AND their metal terminals. (WATCH your fingers!)
Regards,
joecoolvette
Jul 04, 2012 | Gateway MCP61PM-GM (4006254R) Motherboard
Case wiring diagram for intel d845ebt
Jay,
Intel Support > Intel D845EBT Desktop Motherboard > Product Specifications > Technical Product Specification,
http://www.intel.com/support/motherboards/desktop/d845ebt/sb/cs-008791.htm
On this page left-click on the blue - A92200001.PDF
It may take up to 30 seconds before the first page comes up.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
At the top in the header is the page number box, to the right of the Down Arrow.
IF you know the page you want you can go page, by page, until you arrive at the page you want,
Or,
1) Put your mouse cursor in the page number box.
Left-click ONCE.
2) Type the page number
3) Press the Enter key
Go to Page 14.
1.1.3 Board Layout
The plastic front of your computer tower is the Front Panel.
The area of pins (Contact pins) on the motherboard, that the wires (Cables) go to, is the Front Panel header.
P on the Board Layout points to the Front Panel header.
(Front Panel connector)
Note that the illustration of the motherboard layout, is turned 90 degrees to the Right, in relation to how it actually sits in your computer case.
If you turn the motherboard layout illustration 90 degrees to the left, as it should be, the Front Panel header has two rows of pins.
Go to Page 69.
If the view is not very clear for you, enlarge it. Click on the + sign at the top, to enlarge the view. (Zoom In icon)
E points to the Front Panel header, and it's pinout.
Note that with the motherboard sitting in your computer case, the pins are numbered ODD on the top row, and EVEN on the bottom row.
The numbering starts from RIGHT to LEFT.
Top row of pins from Right to Left;
Bottom row from Right to Left;
Pins 2, 4, 6, and 8. There is NO pin 10.
Go to Page 71.
2.8.3.1 Front Panel Connector
A) Pins 1 and 3 are for the HarDDrive activity LED light.
If the HDD LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch. IF a Reset switch is used.
C) Pin 9 is NOT used. This is for the factory.
D) Pins 2 and 4 are for the Power On LED light.
If the Power On LED light is dim when the computer is on, switch the wires around.
F) There is NO Pin 10.
N/C
Not Connected
Regards,
joecoolvette
Jun 09, 2012 | Intel Computers & Internet
Front panel pinout connections for ASUS A8M2N-LA (NodusM3
The Asus A8M2N-LA motherboard was made SPECIAL for HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00820191&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
As such Asus has no info on it.
Looking at the second link posted (Motherboard Specifications), scroll down to the bottom, and click right on - Motherboard Layout
Motherboard layout shown (Direction), is the same as is installed in your computer; Processor to the Top, white PCI slots to the Bottom, Ram Memory to the Right.
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) go to from the Front Panel, is the Front Panel header.
Abbreviated F_PANEL 1, at the bottom right corner of the motherboard, is the Front Panel header.
There are 9 contact pins. Two rows.
Across the Top row they are numbered ODD.
Across the Bottom row they are numbered EVEN.
Coming from the Left side of the motherboard towards the right side, on the Top row;
Pins 1, 3, 5, and 7
Coming from the Left side of the motherboard towards the right side, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
Pin 1 is for the Positive wire. ( + )
If the HDD LED is dim when operating, switch the wires around.
C) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
D) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Apr 10, 2012 | Gigabyte Computers & Internet
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
Hi i have a Codegen model 450x case and i am trying to install a Gigabite GA-P35-DS3R motherboard and am having troulbe with the start switch wires, the cases wires do not matgh the diagram in the...
I'm not sure what you mean when you say the case wires don't match the diagram. You might mean there is already a plug on the end of the wiring, and this plug doesn't match the board header. If you're reusing the case from a name-brand machine like a Dell or HP, this is possible. They often get custom versions of motherboards made, and their front panel connectors are usually a nonstandard layout. On the other hand, in a generic retail case, the front panel wires normally have separate connectors on the ends for the switches, indicator LEDs and any front panel USB and audio jacks.
This is the front panel header diagram I found in the manual for your board (I looked at version 2, but the connections should be the same if yours is a different version):
This board has an Intel standard layout for the header. If your wiring has separate connectors, the start (power) switch wires will plug onto pins 3 and 4. I have never seen a retail case come with anything other than a two-pin plug on the end of the power switch.
If you are dealing with a custom plug on your case's wiring, what you can do is remove the pins from the housing. They almost always are held in by a plastic tab on the connector shell that engages a tang on the pin. Use a thin object like a small flat-blade screwdriver or a knife tip to lift the tab and you can slide the pin out. Insulate each pin with small-diameter heat-shrink tubing if you have it, or a layer of electrical tape. (I prefer the heat-shrink tubing, which is neater and more permanent.) Then you can put each pin over the corresponding pin on the motherboard's front panel header. Unless the pins are very loose, they will stay in place by friction. I often use this technique when salvaging a case.
As for the CPU fan, be sure you have the connector over the right pins. Here is the diagram from the manual:
You might need to rearrange the pins in your fan power connector if they don't line up correctly. This layout looks a little strange.
Dec 21, 2010 | Codegen (PS-450W) (PS450W) 450-Watt Power...
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
POWER SWITCH
Hi sivaprasanna,
Do you still have your manual? If so turn to page 72 for location.
For a close look at the motherboard front panel led to MB pins look at these two pics.
Location of front panel connections;
Item " A " is the front panel MB pins.
Pic two is the layout for each front panel connection;
The power on jumper uses pins 7 & 8.
Pin 7 is positive & pin 8 is negative.
Good luck sivaprasanna!
Mike
Nov 09, 2008 | Intel D850MV Motherboard
Shuttle AV40 Motherboard Logo
1,110 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
