Question about Creative Labs Zen Digital Media Player
My creative zen not turning on
It started displaying the creative logo and got stuck. i reset the player. it shut down and never turn on. I tried all the steps given by customer support still no success. in the device manager on computer it shows a 'USB Human Interface Device' and does not turn on. It neither shows up in 'My Computer' nor in 'Windows media player'. i tried to update its drivers. simply it does not respond. Iam very much disappointed. somebody please help me. Thank you.
  • mcdlt2003 Nov 19, 2008
    Same thing, black screen, only the power light flashing when plugged to USB. Tried resetting before connecting to USB and while connected to USB. Any ideas?
  • bprierierie Nov 25, 2008
    man look i reallllly need help with my creative zen it dosnt want to come on!
silly girl
  • 513 Answers
SOURCE: Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
Posted on May 08, 2006
SOURCE: Zen Neeon frozen completely
Leave it alone for a while, then try reinstalling the Zen Program, then plug it in, then rest it, then try to switch it on. It worked for me
Posted on Oct 05, 2007
SOURCE: MY Creative zen V plus 4Gb will not switch on!!!
You should take a pin and press it into the reset button on the side (NOT the microphone on the top)
Posted on Feb 15, 2008
SOURCE: My Creative ZEN.... Suddenly turned off and won't respond....
I had the same problem. Icontacted creative labs and they told me to reset it using the reset button. (small hole you need to use an electronic pencil to get to it) and then it worked.
Posted on Feb 22, 2008
SOURCE: creative zen
get a paper clip and stick it in the reset hole....that worked for mine :)
Posted on Jun 23, 2008
My creative zen v plus is stuck in shutting down
i think i have a different version of zen but hopefully it'll work for you. i held down the power button and pokes the reset button with a pen tip for about 5 seconds and it finially turnned off! i've had alot of problems with the zen and it sorta happens alot and most times you need to do different things but the same problem usually doesnt come bk. good luck
Mar 12, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen Mosaic 4GB Black
Start in Safe Mode: hold Reset in and hold Play/Pause in, then turn on. Choosing reboot usually solves this problem.
Mar 07, 2009 | Creative Labs Creative Technology Zen MP3...
My creative zen freezes up while shutting down
Mine froze while trying to add radio preset stations. Had to put a pin in the reset hole to recover.
Have tried to understand 'playlists' without success!
Mar 05, 2009 | Creative Labs Creative Technology Zen MP3...
Creative Zen screen is frozen on ZEN
If you have tried the reset hole on the bottom, try the mp3 player recovery tool here.
Feb 12, 2009 | Creative Labs Zen Digital Media Player
Help my creative zen v plus freezes and wouldnt start up.
**** YOURSELF AND THEN TRY TO TURN IT ON IT ACTUALLY WORKS ... DON'T BELIEVE ME GO DO IT
Nov 08, 2008 | Creative Labs Zen V MP3 Player
Zen wont turn on or charge
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Reset
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Sep 21, 2008 | Creative Labs Zen Digital Media Player
My creative zen v plus is not detected by my pc when connected its screen has reddish lines neither it is shutting down nor it is working
Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Message Edited by Jason-CL on 09-11-2006 12:02 PM
Forum Administrator
Creative Labs
Jan 05, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery
Clean Up
Format (All)
Reload OS/ Firmware
Dec 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
Clean Up
Format (All)
Reload OS/ Firmware
Dec 28, 2007 | Creative Labs ZEN V Plus MP3 Player
My mp3 won't start.
You could try reflashing the firmware onto the player. Go to www.creative.com and look for the support section. Search under downloads for firmware for your player and download that. Follow the instructions on the website.
Nov 20, 2007 | Creative Labs Zen Nano Plus MP3 Player
Creative Labs Zen Digital Media Player Logo
35 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
