Question about Panasonic CQ-DF903U CD Player
CD Player won't work but radio does
I was in a bad wreck a while ago and this player was in, when i just hooked it up there is no damage, radio works perfectly, but my cd player doesnt work. Everytime i put a cd in it just goes in and make a whirling noise for a lil min then it ejects, whats wrong wit it and is it fixable?
  • jrs51488 Dec 24, 2007
    cd player started getting statickie and then quit, now a cd will just make a clicking noise and then eject.
  • Anonymous Mar 09, 2009
    i have the same problem but it will read the CD and play it but no sound comes out
SOURCE:
Jexx
  • 148 Answers
SOURCE: Battery dead, boost car, cd player doesnt work anymore...
Get a testlight or DMM and test all of the power wires. It's your only hope.
Posted on Nov 05, 2006
SOURCE: CD player that doesn't play
cut the orange wire (muting-wire)
Posted on Oct 13, 2007
  • 37 Answers
SOURCE: Panasonic CQ-DF903U CD Player
When you unhooked your deck it still had power going to it, you need to unplug your car battery and plug it back in that should reset the deck and get the error message to go away.
Good luck,
Chris
Posted on Feb 27, 2008
  • 152 Answers
SOURCE: i my remote wire is gone on back of my cd player
You could install a lever switch that is fed by the 12+ volt switched head unit feed.
You'll wire it that way so the amp is not left on when the ignition is turned off, and the lever switch serves as a secondary control.
I have a lever switch on my remote to my amp, because "wifie" is allergic to loud....lol
Good luck
Aduz
Posted on Mar 22, 2009
  • 9 Answers
SOURCE: just need to know which wire goes where
orange is normally illumination(not necessary) other is probably cell phone mute
Posted on Jun 12, 2009
Radio and CD-6 player
The humming sound prior to cutting out could indicate a short in the unit itself.....remove unit and have it tested!
Aug 21, 2015 | 2003 Ford F-150
1999 toyota 4runner radio works but cd player won't read cd
I am having the same issue! How did you resolve your problem?! ANY advise would be greatly appreciated!
Jun 02, 2012 | 1999 Toyota 4Runner
The remote for my radio/cd player won't work any longAny suggestions? The model is: jWIN JXCD3250 Classic Style CD/AM/FM
Remove the batteries, clean the battery terminals with rubbing alcohol and Q-Tips and replace the batteries with new ones, if no! I would suggest you have someone look at it, usually find bad solder connections that need touch up.
Feb 13, 2012 | Jwin JXCD3250 Classic Style CD/AM/FM...
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
I got a premier, pioneer DEH-P200 sterio and ive hooked it up to my 92 chevy truck and my 94 camero but in both it powers on. and beeps through the cd player for volume changes and stuff like that but its...
WELL THIS RADIO CD PLAYER WILL NOT WORK WITHOUT AN AMP HOOK UP IT JUST SENDS A SIGNAL TO THE AMP AND THEN TO THE SPEAKERS. YOU MAY HAVE TO FIND THE AMP THAT DIRECTLY HOOKS TO THIS UNIT...
Jul 15, 2011 | Pioneer DEH-P200 CD Changer
My car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
Sep 09, 2009 | Sony CDX-454RF 10-Disc CD Changer
My 93 Boneville CD Player does not work, the radio works fine but it will not play CD's, also how would i install a set of speakers (subwoofers)
the cd player is bad and you can hook up subs through a rca hook up that you can hook to your speaker wires in the trunk the adapter is like 20 bucks at radio shack or local sound installer or buy an after market cd player cause yours will never work again and run rca's off the back of the radio to your trunk
Jul 09, 2009 | 1993 Pontiac Bonneville
Alpine CDA 7843E head unit
if this unit has a motorized face the ribbon cable is bad and will need to be replaced
Nov 25, 2008 | Alpine CDE-9852 CD Player
Radio.
First you need to UN DO your first hook up. Put it back the way it was before you splice. You have evendently spliced the wrong wires. Without schematics colors and stripe won't mean anything.
Be thankful you haven't damaged anything or burn something out in your control module.
You need to find the schematic wiring for the radio.
Or if you have a taple player in the radio, by the tape adapter for CD player. Until you can find out what wires PRE AMP the tape player then you can splice.
Sep 20, 2008 | 1994 Ford Explorer Limited
Panasonic CQ-DF903U CD Player Logo
74 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
