Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother model number 7420 how to re set the drum when i put a n
  • 133 Answers
Open the front cover and pust option and 00.
Posted on May 22, 2009
How do i fix a brother mfc-7420. when it says toners life has ended. we have tried to put new toner and drum in it. with no help. we need to clear the message
check the paperwork that came with the drum unit. Usually there is a sequence you need to follow to clear the drum message such as starting the printer with the front door open. These instructions are shipped with a new drum when you buy an orignal brother drum. If you puchased a refurbished or 3rd party drum you need to talk to your vendor as they should supply these instructions.
Jun 23, 2015 | Brother MFC-7420 Laser Printer
Brother MFC-7420; "Take Drum out; Slide blue tab..."
go online type in Brother MFC-7420 reset and follow details
Jan 30, 2013 | Brother MFC 7420 All-In-One Laser Printer
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
I didn't think that the MFC 7420 All-In-one was suppose to have a drum. I thought a new drum was included with new cartidge
Nope, Drum number is DR-350 and toner number is TN-350 they are different Drum is the one to connect with the toner.
Jun 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
Keep getting Toner Life End Message even after replacing with brand new cartridge. I'm sure it is installed correctly. The Brother 7420 machine won't recognise the new cartridge(TN2025).
Open front cover and hit "Options" button, you should see a prompt to "Change Drum". Don't hit 1 for yes or 2 for no. hit the "Start" button and then put in the number 11. You should see the word "Accepted" in the window. Close front cover and you should be all set.
May 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother Printer MFC-7420
Open the front cover and take out the toner/drum unit. On the top of the drum unit you will see a blut tab that you can slide side to side. Do this 10+ times and this should fix your issue. Make sure to put the blue tab back in the original start position which is believe is to the left on that model.
Sep 06, 2008 | Brother MFC 7420 All-In-One Laser Printer
RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
Aug 26, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother Printer won't accept mostly full toner cartridge
On the side of the cartridge (TN2000) there is a white reset flag, this need to set to twevle 'o' clock, thats towards the black roller. If that hasn't been reset the cartridge will register as low.
Jun 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
