Question about Compaq Evo N610C Notebook
My battery run out in 15 minutes
My lap is fairly used so how do i solve this problem
  • 541 Answers
You need a get a new battery for your laptop then it will work ok
Posted on Nov 18, 2008
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Apr 11, 2016 | Razor E300s Electric Scooter With Seat
My lap top and also the charger adaptor soon after a couple of minutes overheats during windows usage!!!!
Run diags to be sure your heatsink and fans are working. Check for dust clogging air vents. Use PC on a flat surfaces. Check specs for correct amps and voltage
for your PC version.
Nov 28, 2013 | Apple MacBook Pro Summer 2009 Core 2 Duo...
Hp pavilion Dv 7 won't power on even when the lap top is charged.
Pull the battery and plug it in to the wall (in other words rule out the battery). If it still refuses to come on, check out this troubleshooting link:
http://www.techspot.com/vb/topic55208.html
Jan 15, 2012 | HP Pavilion dv7-1130us laptop
The light work on the jeep the horn works, I put the vechicle in park turn the key and it wont start, The the key is turn it make a clicking sound
this sounds like a low battery problem ... the horn and lights do not take much energy to turn on, but starting the engine takes a lot of power. Try jumping the Jeep with another car, or a battery jump pack (available at any auto-parts store). If the engine kicks over and starts, then leave your Jeep running in park for about 15 minutes. After 15 minutes of running, turn the Jeep off and then try to start it again with no jump -- if it starts, you had a low battery, but the issue is probably solved (running the engine recharges the battery). If, after you have had the car running for 15 minutes and turn it off, it does not start on its own, you probably need a new battery (and you should have your electrical system checked as you might have a bad alternator that is not charging your battery). Sears Auto Canter has a great piece of equipment that can test your battery, and your entire electrical system (including the alternator) in just a few minutes. I recommend that you take your Jeep to a Sears Auto Center and have it checked, whether or not the jump worked because their system can make sure that there is not a slow drain on the battery (due to a loose connection or something like that) which would cause you to have the same problem again.
May 29, 2011 | Jeep Grand Cherokee Cars & Trucks
Coolant fan continues to run while van is off......
most modern vehicles have fans that can run for 5-10 minutes after the ignition has been turned off if the engine is hot.
if the fan runs for more than 15-20 minutes there may be a problem with the temperature sensor for the fan.
this would normally be located on the side of the radiator and is fairly easy to change.
if you need more detailed instructions on changing this then please feel free to ask, but if the fan turns itself off within 10-15 minutes then there is probably nothing to worry about.
Mar 30, 2011 | Chrysler Town & Country Cars & Trucks
Power
If the fan is spinning quite fast then the overheating problem is most likely dust clogging the fan and heat-sink assembly. Blasting air into the fan and heat-sink can only make it worst as you are forcing the dust further into the heat-sink fins.
Remove the panels covering the vent and fan/heat-sink, loosen the dust and vacuum to remove this dust off the fan and heat-sink. Check the fan to see if it spins freely, if not replace the fan.
After re-assembling and boot up, if you still have heating problems, addition cooling can be employed by purchasing a laptop fan assisted cooling pad. Place the laptop on top of this pad and the fans on the pad will direct additional cooling air to the laptop's vents.
Mar 08, 2010 | Gateway ML6732 Notebook
My Shark vacuum sweeper will run for 10 minutes and shut off. After it sets for 15 minutes it will run for 10 minutes more.
If it runs on NiCad batteries it probably has programmed batteries which can happen, best solution, get new battery, and use til dead before recharge, every time.
Nov 25, 2009 | Vacuums
How do I use my watch???
I also own a PRS200. The two buttons on the right and top two subdials are for the chronometer function.
The top right button starts and stops the chronometer function: First press starts the chrono. Second press freezes/stops it, so you can record your time. Third press resets the chrono.
The bottom button is for the lap function: on the first press, it freezes the chrono in order for you to be able to record your "lap time", but keeps the chrono running in the background (you don't see this, it's the movement that does this mechanically). When you press it a second time, it jumps back to the running chrono time. You can then press it again to get another lap time, and so on...
In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Feb 23, 2008 | Tissot PRS 200 Wrist Watch
Compaq Evo N610C Notebook Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
