Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
I have a KDF-60WF655 and the lamp light turns on
After trying to turn on the tv, the power light starts blinking and then stops and the lamp light turns on. The tv never turns on.
If I need to buy a new lamp, will it be a ballast, a lamp, a lamp with housing or what? Will I be able to install it by myself?
Thanks,
Joann Herrans
  • 320 Answers
Joann,
If you buy an original Sony lamp (and I would recommend you do) you will get the lamp with the housing and the allen wrench you need to change the bulb. You shouldn't need a ballast.The reasons to stick with an orginal Sony lamp:
1)You get the lamp with the housing. Some of the aftermarkets just send the lamp and reflector
2) the originals have far less problems than the aftermarkets. I have seen replacements fail early and not be bright enough.
If you have any further questions, feel free to ask. If you are happy with this solution, please rate it. Thanks!
Posted on Nov 18, 2008
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hello, i have a problem with my TV. When we turn on TV, after few seconds the screen turns off, and green power light starts to blink, after that the picture returns back on. And in few seconds this...
The problem you are having is likely the lamp is bad and needs replaced this happens when the lamp gets weak replace lamp should fix your problem part # is xl2400
May 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
KDF60-60wf655 lamp relacement problem
Make sure you have the lamp seated correctly
If you used a non sony lamp it may not be compatible
remove the lamp and look to see how the two connectors line up
they are the most important
Jan 27, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kdf-60wf655
There is a lamp driver error in your TV set. Most likely the ballast circuit for the bulb. Depending on who you take the set to, you will pay anywhere from 300 to 500 bucks to have this set repaired. This is why i recommend an extended warranty on all of these types of TV sets. This repair will involve replacing a board, and it could be one out of three of the differant boards that control the lamp. good Luck.
Jul 21, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
