Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
How do I remove/install color wheel/balast on a samsung hl-p5063w
I have no picture. when I turn it on , only get lights blinking. in the start button. Plus there is a humming sound that I used to get intermittntly befor this happened, once it started the only way I could get rid of it was to shut the tv off for awhile, sometimes that would work for awhile ...sometimes not. In addition to no pic there is no sound now.
  • randallhodgs Jan 07, 2009
    i have a samsung 46 dlp tv model 4663w it does pretty much the same thing when i turn it on the lamp light in the on button flashes a couple of times then 2 clicks prolly the ballast? them a winding sound (a fan or motor) i think..then light comes on but no picture or sound..........does anybody know what i can do..........i looked online seem i may need to replace lamp or color wheel...........and lamp had been replaced before but i looked at bulb # and number on unit housing they dont match could this be the problem?
  • alozada Apr 02, 2009
    have a samsung 67dlp tv model HLs6767W when i turn it on the lamp light in the on button flashes a couple of times then 2 clicks no picure no sound,already changed the lamp and the ballast, a winding sound (a fan or motor) i think..then light comes on but no picture or sound..........does anybody know what i can do..........i looked online seem i may need to replace lamp or color wheel........... could this be color wheel problem for sure?
We just replaced our color wheel and it took about 2 hours.  We used this site because it was the only one that somewhat resembled our TV http://guides.fixyourdlp.com/samsung/bp96-01579a.php  Our TV had a loud humming noise and no picture.  We also had to replace the bulb.  Hope this helps.
Posted on Jan 03, 2009
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
My problem is: samsung hl-p5063w. I have a new lamp and it works fine. The fans work all right. The color wheel works well. But no picture, only the screen is black. Low light without image. The timer...
I'm not a tech person, but from what I have learned it sounds like your digital board (input) connections. Try diffrent connections to see if you get a picture.
If you are using a coax cable for your input, try the rca type input. If you still get no picture after trying diffrent inouts, it may just be the digital input board. Again Im not a TV specialist, just sort of informed from the net.
Apr 20, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
HAS SOUND BUT NO PICTURE
okay the reason that the its turning off could be the fan isnt spining fast enoug hold your hand at the back of the tv to feel where the exhaust air if isnt good enough to help cool off the bulb then the fan may need to be replaced also the balast could be going bad and last check the power supply that feeds the balast make sure its a constant dc voltage
Mar 28, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I just replaced the lamp on my samsung HL-P5063W (DLP TV)...now the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise.
www.Partstore.com should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
No picture after replacing color wheel
every time I see this itbis a cable or plug that was left out or one that got pulled on and pulled the connector up out of the plug a little, you need, and not by sight by your hands to go over every plug and connector till you find one.
Larry Dillon
Aug 01, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
Jul 18, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
1,670 people viewed this question
Jerry Greenberg
Jerry Greenberg
