Question about Delphi Roady XT XM Radio Receiver
Power Problem I use my Roady exclusively at home. When I try and power it up (in its home docking cradle) the screen flickers but it won't turn on. Same problem when battery - powered. I tried a different cradle and same problem so the problem seems to be in the Roady. I tried contacting Delphi for repair - a total waste of time. Can you recommend an after market 3rd party repair service for the Delphi Roady? Thanks, MG
  • 2 more comments
  • mikebivins1 Jun 24, 2008
    have antenna probems will not work on either antenna
  • Anonymous Sep 27, 2008
    I just started having the same problem, after two years worth of good service; this thing is a piece of junk!
  • alpowell2000 Oct 04, 2008
    I have no power to the delphi reciever. It also will not work with the bateries?
  • ACE360 Nov 22, 2008
    Mine has been problem-free for the past 2 years. All of the sudden, it won't power up.
I had same problem - tried reciever in my car and no problem. I suspect the power supply and have ordered another.
Posted on Aug 25, 2008
Delphi roady2 SA10085 XM Radio Receiver with Car Kit
Sounds like its the dock itself. Have you tried using the home dock with the vehicle power or visa versa? This should help you confirm what the problem is. You can get a replacement power adapter here:
http://www.tss-radio.com/products/xm-car-power-adapter-for-6-volt-receivers
A cradle may be difficult to find, but TSS Radio can help you look.
Jun 05, 2012 | Delphi Roady2 SA10085 XM Radio Receiver...
I have 12 volt power coming to the cradle, and power coming out of the pin connector in cradle, but the SP5 does turn on.
Check the center pin on your unit, and also check if your dock connector has any damage. If it is not damaged, then push on the unit while it is docked. If it turns on after 30 seconds then you have a cold solder joint on your power connector. Just remove the back cover and solder the barrel connector's pins back down. There is one on the left and one on the right, both must be soldered in order to receive power.
Dec 30, 2010 | Sirius Sportster 5 Satellite Radio...
My roady xt does not have a fm select option on the menu
You need to have it in the AUTO base/cradle - AND - you cannot have anything plugged into the LINE OUT or AUX OUT jack, as it will disable the FM transmitter. Try unplugging the audio output, then you'll be able to select the FM transmitter again. I believe that they removed the option from the HOME cradle/dock all together because of regular AM/FM radio stations complaining to the FCC that the transmitters were too strong (in other words, they wanted to hurt satellite radio competition or slow it down as much as possible by forcing Sirius and XM go back and redesign their radios for a much weaker or NO FM transmitter).
Nov 07, 2010 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
Overheats and cuts off
check the antenna and see if its grounded out anywhere, like if its chaffed and grouned to the car somewhere. If not try turning on the unit outside of the car or using it in the home dock, if it does the same thing its a problem with your unit or car dock
Feb 21, 2009 | Delphi Roady XT XM Radio Receiver
'Antenna' message on Roady
Hi there check the back of the docking staion. The connection is LOOSE or try to make sure that you have not keep it in the sun for to long just let it cool down
Rate FixYa Expert Kindofcheap
Aug 30, 2008 | Delphi Roady SA10035 XM Radio Receiver
It turns on, but that is it
Won't turn on just flashes, tried a sister unit from truck and it works fine.
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
279 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
