Too much magenta on the screen
I have a Philips 170b4bgbs monitor which is displaying too much magenta. I have tried re-setting the colours but the magenta is still prominent. I run Vista Home Premium on my PC. Will a monitor driver update help?
  • christine707 Nov 18, 2008
    Thank you for getting back to me so quickly. It seems odd that the colour has suddenly changed. I have tried adjusting the colour in the OSD to no avail and I'm sure I have the latest driver for my monitor. I'll try the video card - thanks
    Christine
    Guru:
  • 1,342 Answers
There seems to be only one driver for all Operating Systems for this monitor. You can try going into the OSD (On Screen Display) and adjusting the color. You can also check to see if there is an updated video driver for your video card. This may be your problem rather than the monitor.
Here's a link to the Philips Support page for your monitor where you can download the User's Manual and driver. But it seems the driver has not been updated since 2005.
Posted on Nov 18, 2008
Philips low contrast crt
tried to adjust in the screen menu set up adjustment, just let me know if can not get with adjustment.
Jul 18, 2012 | Computers & Internet
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Viewsonice VX2835wm strongly magenta
check u'r degusing section u'r degusing is not working if it works then change CRT
Jul 20, 2009 | Philips 170B4MG 17" LCD Monitor
Monitor display and colour settings are not correct
Did you install the monitor driver? It sounds like you did not. 75Hz refresh is high, try reducing it to 60Hz at least long enough to get your settings fixed.
May 27, 2009 | HP D1560 Deskjet Printer InkJet
Vertical line in imac 17" core 2 duo intel 2006 model
Attach an external monitor (you may need to buy an adapter to try this) and turn on Display Mirroring in the Display preferences.
If the same symptom shows on the external monitor, then you've got a video card problem. If not, I'd say you're screen has some kind of damage of failure.
Sorry, but either one is likely going to require a trip to the Apple Hospital.
At least with the display problem, you could use the external monitor until repaired.
Mar 16, 2009 | Apple iMac G5 Desktop
Too much magenta
Click Here to view the answer to this question.
Nov 18, 2008 | Philips 170B4MG 17" LCD Monitor
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
Computers & Internet Logo
519 people viewed this question
Alun Cox
David Payne
David Payne
