Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
Frigidaire portable dishwasher wont start
I used this dishwasher a number of times already with no problems and now it wont start. I plug it in and turn the dial to normal wash and its like its getting no power. It doesnt make a sound. Any help?
  • zucchini420 Nov 18, 2008
    The outlet works fine. I even wheeled it over to another outlet. It's a portable dishwasher.
  • Anonymous Jan 13, 2009
    Just moved in, this dishwasher is here but not on...can't figure out ??!?!
  • 88 Answers
Check the outlet where you plug this dishwasher into make sure you have power to it you may have a popped breaker. reply back if this is not the cause.
Posted on Nov 18, 2008
  • Alan Matzke
    Alan Matzke Nov 19, 2008
    There is large number of possibilities that could be going on. I will list a few the cord could have a break in it , the motor my have a short or a dead spot in it, a wire may have come off inside which will break all electric workings of the dishwasher. I have another question for you how old is this dishwasher?
How do I reset the code.the lights are lit 4 hour delay, rinse only steam clean.
THIS DISHWASHER WAS RECALLED BY MAYTAG.. You might want to call them to see if it is still covered.
If already repaired you might try:
Normal - heated dry - normal - heated dry. then try to use the machine.
Oct 19, 2015 | Maytag MDB7809AWB - MaytagR JetcleanR Plus...
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Wash cycle doesn't seem to work. bottom has water
Your gonna have to pull the dishwasher out and shut off the water line. Then disconnect the water hose and get you a bucket. Then turn on the water line to see if water comes out. If water comes out strong then your water supply line is good, which means your inlet port on the dishwasher is clogged or hard water has clogged the little holes in the dishwasher arms. Dishwashers are meant to leave a little water remaining at the bottom to keep the sensor from burning up.
Feb 16, 2010 | Dishwashers
How to Start And use ???
I have the 6040 model, and it has a number of buttons on the left, and a dial on the right.
if yours is the same, then you need to select a program using the buttons "Normal" for example, then turn the dial to just after the top A selection (I mean just after this, by a few mm, it clicks past the A slightly)
this will then do a pre-was, and the main wash you have selected.
The other buttons are fairly self explanatory, like half load for a half load, pre wash to only do a pre wash etc...
Hope the helps!
May 23, 2009 | Ariston Technologies Dishwashers
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher conrol panel light comes on but it wont go into wash cycle
All dishwashers usually start by draining first, if your machine does not detect that your machine is empty it will not start to wash. There are a few resons why this can happen, could be the pressure switch is stuck. Some machines ie bosch have a float switch mounted in the base so if your machine has leaked underneath and lifted the switch it will just stay on drain.... would help to know the make and model number
Jun 14, 2008 | Dishwashers
Frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Apr 18, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Dec 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
268 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
