Question about Kenmore 74252 / 74254 / 74259 Top Freezer Refrigerator
Water stopped coming out of the dispenser
Went to get water this morning and the water dispenser does not give me water anymore. I hear the motor running when I hit the button. Nothing comes out. I ordered a replacement catridge. Would that be a catridge that would cause that? Can I test without the cartridge? I have a Kenmore 74252 with the water in the upper left corner of the fridge. Any help would be appreciated.
  • 1 more comment
  • Dan DeCarlo Dec 27, 2006
    mapex5
    I figured out what the issue was. I had the temp turned up a little to high and the water froze in the lines. It was only a touch over the recommened line. I turned it back down waited a little while and I could hear the water moving throught he ice. I had also changed the filter first and that wasn't it, obviously.
    deca
  • minnie46 Mar 01, 2008
    First of all ice and water dispenser stopped working.We had to have our water heater replaced and both started working again great well that was 4 days ago well this morning they both stopped again can you please help.
  • gemania Dec 06, 2008
    I have the same problem.I changed filter and then let the water run for some time and thought i had gotten rid of all the air lock. In the morning i went to get water and I can hear the motor .It dispenses ice  but no water.
  • 237 Answers
Your filter would have to be VERY dirty and fully plugged up for that to happen along with no ice maker production too. Did you happen to move the frige recently where the line in the back is kinked closed? Any recent plumbing work could have put debris in the line and plugged the screen on the solenoid valve. Simplest test is to pull the frige out and see if you have water from the wall valve. If you disconnect the line at the frige and turn the wall valve back on you should have water flow of course (clean without debris). It may be that the line is frozen up also, that means leaving the unit off for a day to see if the line will defrost. If the solenoid valve is working you would hear the loud "click" of the valve.
Posted on Dec 11, 2006
I also have the same Kenmore 74252 and my water dispenser also stopped working. There are no kinks in the line, it has not moved. No recent plumbing. Town water so I seriously doubt debris is in the line. Like Deca, I also can hear the motor run when I press the button, but not a drop of water comes. I'd like to find out from Deca if he found a solution but I dont see a way to contact him.
Posted on Dec 27, 2006
Whirlpool side-by-side fridge water dispenser stopped working this morning. When I depress the lever, I can hear it buzzing, but no water comes out.
Have you checked the water pipe is actually producing water
- Not kinked
- Vale turned on at wall
If you are still making ICE... your drinking VALVE is defective.
Without a model number we can speculate no further.
Carnac the Magnificent
Apr 26, 2017 | Whirlpool Refrigerators
What would cause both the water and ice dispenser to stop working?
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 07, 2017 | Whirlpool Gold GI5FVAXVB 25 Bottom Mount...
There is no water coming out of the water dispenser. I changed the filter and check the water line coming from the pipe, there is water coming thru the water line. when I push the water dispenser lever I...
Well, there is no "motor" for the water dispenser, only a solenoid valve. However, there could still be a problem with the solenoid even if you do hear it when its energized. Hearing it make a noise does not mean its working properly.
Aug 13, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
GE Monogram ZFSB26DRSS- water dispenser problem
Disconnect the water line at the water inlet valve on the back and try the dispenser to see if water comes out there and see if you hear the valve work. If the water comes out here then the problem could be the filter. The mesh screen in the water inlet valve could be stopped up. Disconnect the water supply line to see the screen. You may have to remove the cardboard backing to see the valve on the back of the freezer.
Oct 05, 2009 | Refrigerators
Where is the motor for refrigerator water
When you try the water dispenser you should hear the water inlet valve which is on the back where the water supply comes in. If you do hear it then Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
If you don't hear the valve working the dispenser switch is bad.
Aug 13, 2009 | Refrigerators
Water Dispenser on freezer door does NOT work
change filter check tap see if water is shut off may be is the water valve
Apr 03, 2009 | Admiral 26 cu. ft. Side-By-Side...
Filtered water quit working on my Frididaire side by side
although you had waterto the bottom of door when disconnected, did you try to dispense water while unhooked andsee it flow??? because just unhooking it will allow the resivoir of stord water to flow out by gravity, giving false sense of water working., if indeed it did work the you have a frozen water lin within the freezer door itself, ait tricky to defrost. aside form unplugging unit and allow to thaw out, or pulling line form liner not going to be easy to thaw the line. if you indded still hear the "hum" after disconnectng water under door, then it soundsas if you have a bad water inlet valve located behind refrig where the water atteachges to the refric, no repairingthe valve it needs replacing
Nov 20, 2008 | Frigidaire FRS26R4A Side by Side...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Kenmore 74252 / 74254 / 74259 Top Freezer Refrigerator Logo
918 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
