Question about Gateway 7405GX Notebook
Power Cord Slot Repair for a Gateway ML6230
I have a Gateway ML6230. I need to wiggle the power cable in the back for it to stay connected to the power source. I've eliminated the cord as the problem by trying my cord on another PC and a new cord on my laptop. There's obviously something loose. The problem I have is trying to take it apart so I can get a look at it. What't the best way to disassemble this notebook.
  • 458 Answers
You need a DC Jack Replacement//
Posted on Nov 18, 2008
Power supply cuts out on Gateway zx6000 all in one computer touch screen
If the cable is a "Kettle" type, you can get one in any electrical goods store.
Feb 11, 2013 | Computers & Internet
I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 21, 2011 | Gateway ML6230 Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
My computer keep crashing
Try to turn off the pc, then remove the cables and the battery. Then press
and hold the power button for 5 seconds. Then reinsert the cable and battery on the
laptop. Turn on the pc and check if it keeps crashing...
May 10, 2010 | Gateway ML6230 Notebook
Laptop will not charge. After wiggling the cord
That's a short in the power input section of the motherboard- I've found, much to my dismay, that the power input/charging circuit on these laptops is not a separate circuit board as it is on some other models, but is a small area of the motherboard itself. You'll either need to have someone repair the motherboard or replace it entirely.
www.dfwsupergeek.com
Feb 16, 2010 | Gateway MT6705 Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
A bad connection between the power jack and the
What needs to happen is on the motherboard underneath the power jack, there are solder points that have hairline cracks in them. The best way to fix it is to remove the motherboard from the laptop and to resolder all the solder points for the power jack.
Once you do this then the power should stay on cause wiggling the power cord won't cause the laptop to turn off.
Aug 10, 2009 | Toshiba Satellite A205-S4707 Notebook
Power unplugs on laptop, black screen, computer still running
It's a common trouble for the power cord from the adapter to break inside the insulation near the plug. This is because of frequent flexing of the cord near the plug. When this happens you'll see the power light on the computer go out, and wiggling the cord sometimes gets it going again. Without the power input, the battery doesn't charge and the laptop won't stay running.
This sounds like what's happening to your computer, and should be fixed by replacing the adapter. Generic replacements are available at reasonable prices from online vendors and at Radio Shack and big computer retailers. It's also possible to repair the adapter by cutting the cord back and soldering on a new plug if you or someone you know has the tools and skills.
Please take a moment to rate this solution if it's what you needed. Thanks for asking here!
Feb 25, 2009 | Computers & Internet
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Gateway 7405GX Notebook Logo
163 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
