Question about Microsoft K5100141 Keyboard
''r'' keyboard problem.
Hi
can someone help please, i have a single key issue, the trouble with this is my keyboard is wireless and my mouse too, it is a microsoft keyboard i bought at a fair, however i can't remember which stall i got it from.Upon typing i would do an e-mail and check back and noticed the "r" or "R" would be missing.
So naturally i popped the key off to inspect and could see no signs of damage etc, i am not a user that "thumps" down on the keyboard in general, but this is real annoying and i am simply not getting anything from this particular letter at all, my only solution is to have a "example of r & R on a note pad on my desktop and copy and paste when needed, its getting a real pain to do this and wondered if there was a solution or is it a new mouse and keyboard?
My problem is at present i have a young family and things are tight at present with the current situation, any solutions would be appreciated.
Kind Regards
Simon (using pc at work)
  • 903 Answers
That is a strange one indeed, it only points to the conclusion that the key is damaged when pressed down, so it does not read.
Have you installed the software for the mouse and keyboard? I don't know if it would make any difference at all but it is worth a try.
http://www.microsoft.com/hardware/download/download.aspx?category=MK
try here to download the software, entering your model number etc...
Posted on Nov 18, 2008
Dell km632 wireless keyboard left alt key not working
If the issue is only 1 key,
Please try rebooting system in safemode and check if 'Alt' key works (to figure out if the issue is with OS or Hardware)
You can even try getting into BIOS and check the Key functionality.
Can try to clean or blow the dirt around the Alt Key.
If nothing works need to replace the Keyboard.
Thanks.
Feb 20, 2014 | Dell Wireless Keyboard Optical Mouse w0147
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
Key board help :{
The keyboard and the mouse work on different wireless sensors. Your wireless keyboard should have come with a receiver too. Unless the mouse and keyboard came together as a set, you'll need two different receivers. Check the battery compartment of the keyboard for the sensor. Some models have a hidden area there to store the usb key for the keyboard.
The only exception is if the keyboard is bluetooth, and your computer already has a bluetooth receiver in it (many laptops and phones come with this feature, lately). You will have to check the website for your keyboard's manufacturer to download drivers. You may also be able to order a replacement USB key for it, but I've never been able to. :P
Best bet is to contact the guy you bought the keyboard from and ask him/her: "Where's the USB receiver for this keyboard you sold me?"
Apr 23, 2010 | Logitech Wireless Access Duo Optical...
Im haveing trouble with my wireless microsoft mouse its called Microsoft:wireless Notebook Optical mouse 3000.... Ok the red light underneith my mouse will come on... but when i plug in my adapter the...
On the adapter there is a small red button. This button must be pushed, then the red button on the bottom of the mouse must be pushed. The mouse light should blink and you should be able to use it.
Mar 27, 2010 | Microsoft Wireless Notebook Optical Mouse...
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
Nothing on key board works, is something locked the mouse works. i have a wireless laser desktop 5000 i am using another key board to type this. please help
Did it happen out of nowhere? or did you do something?
If it happened out of nowhere. The keyboard is probably dusty inside. FInd someone who can open the keyboard and clean all the switches.
Also, check if the cable it ok, it might be jammed or a pin inside might be broken.
Aug 07, 2009 | Microsoft Wireless Laser Mouse 5000
Wireless Mouse Problems
make shore that your receiver is directly in front of it
Jul 06, 2009 | Acer Keyboard for TravelMate 2300, 2410,...
I have a Wireless Optical mouse 2.0 and a wireless keyboard 1.0A.  I am having an issue with the mouse not responding to pressing the keys but it is erratic.  I uninstalled both programs and...
i got a microsoft wireless mouse opitcal 2.0 at car boot sale no instrutions with it or cd can any one help i have a wireless laptop with vista 32 bit help please easy instrutione please
Jul 09, 2008 | Microsoft Standard Wireless Optical Mouse
Keyboard map for Microsoft Wireless Optical Desktop Pro
when i go into keyboard properties there is no 'key settings' option
Jan 16, 2008 | Microsoft Wireless Optical Desktop Pro...
Changing the batteries on the BenQ Wireless Mouse
If you slide down (hard) the panel beneath the 2 clicker keys, you will find a battery compartment with space for 2 AAA batteries7f60d17e-8b58-4076-acc1-563ab4428c0d.jpg
Jul 30, 2007 | BenQ M310 Wireless Mini Optical Mouse
Microsoft K5100141 Keyboard Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
