Question about Bosch Exxcel WFO 2465 Front Load Washer
Bosch WFF 1800
Hi I have a BOSCH WFF 1800 washing machine that fits great in my kitchen and although its old i dont want to change it as it matches everything else. Today it was working well for 2 loads then next time it got as far as the rinse / spin part of the cycle then it started making a buzzing noise and the drum stopped moving. It was rotating during the rest of the cycle ok. Then the Pre-wash light came on and started flashing and it went to the end of the cycle without emptying the watter or completing a spin cycle. We took the back off and can only see a single belt which looks fine as does all the motor and gear driven by the belt. Is there a second belt that takes care of the spin cycle that i cant see or is it a problem because of the water still being in the tub that is preventing it from spinning? Your help please would be greatly appreciated Thanks
  • 1 more comment
  • Anonymous Feb 03, 2008
    exactly same problem looks like motor brushes hit motor with hammer started working fine for next month then happened again replaced brushes works fine now
  • paolawoj Apr 26, 2008
    i have the same problem but i dont have a manual and dont know where is the filter. can you help me?
  • Anonymous Mar 19, 2014
    On the woollen cycle the machine skips through to the end. How might I repair this and how much might it cost.
    President:
  • 1,294 Answers
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Posted on May 21, 2007
How can i sovle this
Posted on Jan 25, 2009
2 Suggested Answers
SOURCE: Bosch wff 1800 How to open the door after wash
Press the "door" button.
Posted on Jan 26, 2010
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
We have a bosch WFF 2001 washing machine, the pump will not turn off and the spin light remians on
bosch WFF 2001 washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 16, 2011 | Washing Machines
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
May 23, 2009 | Bosch Washing Machines
Washing Machine Belt Bosch WFF20
Peace Friend,
ngafm At your service!
You asked,
The belt has come off my Bosch WFF 1800 washing machine and I'd like to try and refit it - what should it go around?
The belt did not just come off! there is a reason it came off!
You may want to put it back on. But the problem may not be just the belt.
Sometimes the belt comes of prematurely due to another problem in a Bosch. You bough the top of the line machine and it deserves the top of the line service.
Or you may find your self paying twice for a job that cuold have been done once the right way!
Please save your self some money and get service on this particular machine!
Bless You,
ngafm
You are welcome to write me and let me know how it goes.
Please give me a good rating for this fine advice I just give you, as i would my brother.
Sep 07, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Bosch Exxcel WFO 2465 Front Load Washer Logo
2,187 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
