Question about Hotpoint VLXR1020A Top Load Washer
Washing machine noise
I have an older Hotpoint washing machine. It is top loading and the water inside comes out of the side, not the back. Problem: It filled and started agitating today and started making a big high pitched whine. I did not let it finish, as I had to leave the house. Is is burning something up or can I run it that way? Thanks! Lisa B. :-)
  • 4 Answers
No sounds like the motor or lift spring don't run it if you smell burning call a tech.. and u can find a good tech that works from home the machine is not expencive enough to pay top prices
Posted on Dec 11, 2011
My washing maching will not spin out all the water in the spin cycle.
Posted on Dec 26, 2007
The washing machine just stops at the rinse cycle. It does a buzzing humming sound and there is no water coming out. The machine is a concept ll model # CDM 2000 RW 439 top load washer.Thank you
The humming sound i believe is the water valve open and calling for water but for some reason no water is coming to it from the house water supply..check that faucets are open and rubber fill hoses on back of washer arent pinched and restricting water flow into washer
Gene
Aug 24, 2011 | Hotpoint Washing Machines
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
Machin fills with water,washes and then fills again
hotpoint wma turn off the power and you are looking for the presure w
switch and chamber , the switch is at the back of the soap draw by the valves on the left hand side there should be a hose going into it take it off and blow through it if nothing happens pull the machine out and at the bottom of the back there is a white plastic cover take it off look for the sump hose and on the side of it there is a whit plastic tube this is the presure chamber clean it out might be blocked
Jun 27, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint washer not rinsing
If it is at the rinse or spin cycle it could be something trapped in the pump, for the water can't drain quickly enough when the machine starts to spin & the water gets forced back up through the soap dispenser as there is nowhere else for it to go. Check your filter too.
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
COLD WATER WASH
Turn water cold water valve off by hose. Unscrew hose from both ends. Clean out filter inside the end of the washer water valve where the hose was connected to the machine. Check to make sure there is not a screened washer in either end of the hose which may also need cleaning. Reattach and turn water back on.
Oct 11, 2008 | GE WBSE2090A Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Hotpoint VLXR1020A Top Load Washer Logo
140 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
