Question about HP Office Equipment & Supplies
Printer connection - HP Office Equipment & Supplies
    Master:
    Sergeant:
  • 461 Answers
Not sure which HP model you having the problem but below link might be useful to find a solution
http://etech.maiila.com/
Posted on Nov 18, 2008
Wirelessly connect to hp deskjet f380 printer
This model printer only has USB printer connection and it cannot be connected to a wireless network directly.
If you have a wireless router then you can connect a print server to this HP printer and then connect the print server to the wireless router. This will allow you to print wirelessly yo the HP printer when you configure the printer server and configure the printer driver in the computers to connect to the printer port IP address of the print server.
Jan 26, 2012 | IBM Computers & Internet
I am trying to install a printer to in my Dell Inspiron laptop 1545. I have the printer connected to the laptop through the ethernet port. But I can not get it to pull up the printer at all. Is the...
Hi lesstravelro...
No, the printer does not connect to the ethernet port.
Before you hook your printer to your laptop besure to run any softwear that came with the printer.
I would also recommend that you go to the Manufacturer's website for updated drivers for your printer.
Your printer will have a printer port or usb port on the side/back of the printer to plug the printer cable into the printer.
You will plug the other end of the printer cable into a usb port on your laptop.
Please take time to rate me thumbs up
Sep 21, 2011 | Dell Inspiron 1545 Notebook
How can I connect my printer to my wireless network
If you have a wireless-enabled printer, you can use the printer's configuration to connect it to the router. If you have a wired connection printer (ethernet port) connect it to one of the ports on the back of the router with an Ethernet cable and the printer should sort itself out. If your printer is not network-enabled, you will need to connect it directly to a network-connected computer, then use Windows' sharing settings to share the printer to the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
Can I connect my canon mp240 printer by wireless
The Canon Pixma MP240 canot be connected to a router wirelessly. You could buy a USB printer hub which would allow you to connect your printer to a wireless router. Basically, the printer would connect to the hub over USB, the hub would connect to your router over the netowrk cable, and this would allow you to connect to the printer wirelessly.
Mar 05, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Printer says "printer is currently
The printer is connected to the rest of your computer with connecting hardware. If the connecting hardware such as connecting cords or connecting pins are damaged or not secure, then printer would be offline. Users facing the printer offline issue are recommended to check the connecting hardware and if the connecting hardware is found damaged, they would have to be repaired to solve the issues.
Jan 24, 2011 | Brother HL-2170W Laser Printer
I keep getting ''Printer connection failed'' message
It is seen that if there are any issues with the printer drivers, issues like connection failure may occur. There are chances of drivers being outdated and corrupt. In such situations, you have to update the drivers. If there is any yellow exclamation mark next to printer driver, You need to replace that corrupted driver with the correct one. Before the installation, you also need to check for compatibility. Sometimes, incompatibility would cause issues like printer connection failed, etc.
Get more information and help to fix Printer Connection Failed . Hope this information helps you.
Jan 28, 2010 | HP PSC 1315 All-in-One Printer...
HOW TO CONNECT PRINTER WITH PC?
first you have to connect with the power
then use the printer cable to connect the printer with your pc.
If you can mention the printer i will tell how to connect with the pc
Normally in new printers they use the USB cables to connect printers.
OR the parallel port to connect printers like dot matrix ( in this port there are only one port are in the behind the CPU it is a normally biggest connector )
Nov 07, 2008 | Epson LX-300 Matrix Printer
Printer 6540
First of all u need to assemble the printer and need to ensure that the printer has a steady green light on Power..
If any light blinks it means there is some problem with the printer..
To connect the printer with your Laptop u need an USB cable which has a rectangular connector at one end wich will be connected to the Laptop's USB Slot and the other end of that cable will have almost square connector wich will be connected to the printer...
Before connecting the printer U need to install the Software on the Laptop and connect the printer when system prompts..
remember the printer should be powered on while connecting to the system..
Nov 01, 2008 | HP DeskJet 6540 InkJet Printer
Connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Oct 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Ben Johnson
