Question about Toshiba Televison & Video
Red screen i can not get the redness out of the screen.
  • 153 Answers
Normally this kind of problem are cause by loose terminal of components in the circuit board at the end of the Cathod Ray Tube. It needs resoldering, see if theres any crack solder at the terminal of any components and do resoldering. That might help.
Posted on Nov 20, 2008
  • 41 Answers
The problem is either u have a loose connection on the chroma board of the tv that is connected to the tube.It should be resolder.if it does'nt work maybe your tube seems deffective.
Bravia kdl-32l5000. Why does it have a red screen?
Color circuits are messed up and need repair.
Mar 05, 2016 | Sony Televison & Video
Red tint to screen
If the model is a 50v500 the real question should be does the set have a red oval area in the middle of the screen (entire screen not red)---if the entire screen is red you have a chance---it has a red oval area and it needs a new optical light engine----you will have options also but limited if that is the case.
Aug 26, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Display has red tint across entire screen. Could it be the bulb? If so, is that still available? Approximate cost?
two possible solutions----either a problem on the small circuit board that is connected to the RED picture tube OR the red screen control is turned up too high. These sets have a small square block with RED,Green, Blue screen controls(same place also has red, green, blue Focus controls) if you remove the speaker grill you will find an inspection plate made of masionite---the focus/screen block is visable behind it----get a flashlight and look carefully at the block---one row of 3 plastic shafts is Focus(don't touch those) the other 3 are Screens(you should see R, G, B marked) go to a blank video input(one with nothing attached) and turn the RED SCREEN CONTROL JUST SLIGHTLY TO THE LEFT UNTIL the red goes away.
Aug 06, 2009 | Mitsubishi WS-65613 65" Rear Projection...
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
Apr 06, 2009 | Televison & Video
CRT problem
you need to adjust the red screen control of the crt under the speaker grill turn it down with the tv running.
Mar 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Oct 13, 2008 | HP Pavilion M703c 17 in.CRT Conventional...
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
Red screen
how to lower the red screen voltage?
Nov 07, 2006 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
