Question about Toshiba 55H70 55" Rear Projection Television
Accessing sevice menu
I have a Toshiba 48pj5ue rear projection TV with some small convergence issues that can't be adjusted out with the standard user controls. I would like to know how to access the sevice menu to do finer adjustments. I'm sure it's probably similar to most Toshiba rear projectors in it's menu structure so if someone has something similar and knows how to access the service menu, I'd appreciate some help.
  • 65 Answers
I tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Posted on Dec 09, 2006
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
Do lamps have adjustment? I have a yellow and blue rainbow effect along bottom of screen. I am pretty handy and well equipped.
This would be a convergence adjustment. Check your user menu on the tv. Look for an item under video settings for a something called "Converge" or "Convergence". See if you can adjust it enough to fix the problem. If not, you may need to access the service menu and adjust from there.
Feb 16, 2011 | Toshiba 42H81 42" Rear Projection...
I just replaced the blue projector. How do I set
Coarse adjustment is done by adjusting the convergence coil on the neck of the tube, also the skew is adjusted there. The user menu should have a convergence adjustment option.
Jan 07, 2010 | Toshiba 50H72 50" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Convergence
There is no code for sevice on this set when you pull up menu and to to setup do you see convergenge if not you have a blow fuse next to your flyback on power supply broad FL231 middle fuse they look like capacitors small brown square.
May 23, 2008 | RCA D52W19 52" Rear Projection Television
Toshiba tv model # tp55h60
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
Convergence Issue...Toshiba TheaterVision HD 55H70
You probaly should be able to access the controls for that through the service menue. I dont have that info. However you can get a service manual for 10.99 at the following link, and if you purchase one they will mail it to you, unless you go back to the site and click on the contact them link and request that it be emailed to you. they also offer free support with the purchase of a manual so they can help you diagnose your set. I am one of their techs also. Heres the Link.
http://servicemanuals.vstore.ca/
Jan 16, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
267 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
