Sharp AL1216 - error code H4
HOW TO SOLVE THIS PROBLEM ?
  • Anonymous Mar 10, 2009
    h4 code bliking
  • 2,794 Answers
H4 means the heat rollers aren't functioning. It could be thermistor replacement. You can get fuser parts at precission roller.com if you want to fix it yourself.
Posted on Nov 20, 2008
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
Code H4 comes up when the sharp copier ar-153e is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
H4 normally is the problem with the fuse unit caused by thermistors or therm-state charge them then clean it by sim 14 but first check if the connector and fame then do sim 5-02 to check the lamp status
Oct 23, 2015 | Sharp Office Equipment & Supplies
[H4-00]SHARP system error
A H4-00 error code is a problem with the fixing unit. Odds are you will need to replace the fixing lamp or thermal fuse or the thermistor to solve your problem. You did not tell us what model of Sharp you have? There are many different ways to reset the code. Good Luck
Dec 22, 2012 | Sharp Office Equipment & Supplies
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Jun 04, 2009 | Sharp AR-M237 Copier
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
205 people viewed this question
k24674
jasbo
jasbo
