No signal!! hi, i just knew that you are a professional. i left this radio for over 7 years and when i tried to use it, first i got nothing but after tuning forward and backword in FM/am it works a little with a sort of boatmotor sound which goes away after little working. after a little, everything was gone, i cant recieve any signal now. well i am a biology studier :D with some skills in electricity so i am not a pro. can you help me fix it on my own? i have the service repair manual sony_icf-sw7600. i can send it to you. thanks happyniceyear@yahoo.com
  • 5 more comments
  • happyyear Nov 18, 2008
    Thanks alot sir, but do you think i can do it with the soldering iron?
    http://www.siliconsolar.com/shop/solarim...
  • happyyear Nov 19, 2008
    i will try to fix it, and when done, i will tell you.
    the problem about diamonds is that they are already locked :( sorry.
    but if you can tell me how to disassemble and their place  in some pics, i would really appreciate that.
    thanks you sir, you are really a pro, and if i have the chance of changing the rating i will do it.
    i made it 4 blue diamonds.............thanks
    no problem about disassembling, already found a tutorial. thanks again, all what is needed now is buying the caps.
    can i change them to ceramic caps?
    in egypt, and the service here is just a **** for sony. they tell you a thousand thing is corrupted and need to be changed for lots of money. and when they are done, it is either not working, or going to stop working after a while.
    so thanks for helping me :D
    can anyone remove my email up their? i can't remove it.
  • dbcooper Nov 20, 2008
    I have a similar problem. After 8 years in a drawer, I seldom get a signal. But now and then it will work for a few seconds.
    Mind reposting the solution?
  • 10,594 Answers
Your Sony ICF-SW7600 Radio requires all Electrolytic Capacitors replacement and electrolytic caps are shown in below picture.
Thanks for service manual offer, I already have it as professional.
Posted on Nov 18, 2008
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Nov 18, 2008
    Its nice solder iron shown in provided link and that should be 30 Watt.
    If you have good solder skills then you can do this job easily.
    Good luck.
    Good luck.
    Information provided deserves 4 blue diamonds rating....what do you think?
    Shahid Electronics Nov 19, 2008
    Thanks for rating change. :)
    Ceramic caps wont work and replace them with electrolytic caps only.
    By the way what country do you live?
    Thank you.
    Hahaha
Cd is stuck
It would certainly help if we knew the year and radio model.
06 and newer it could be a bad CD drive or a faceplate PCB issue not allowing the signal to get to the drive.
for repair option contact iron cross audio
www.ironcrossaudio.com
Feb 23, 2011 | Harley Davidson 426290 AM/FM Radio
My xm radio stopped working in a 2009 silverado.
Having the same problem in my 2009 Malibu. Have received 8 refresh signals and talked to the XM Techs 4 times. Taking car to dealership on Monday. Highly frustrated.
Jan 05, 2010 | XM Radio (XMP6000)
Tv just quit working
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 11, 2009 | Emerson TS1997 19" TV
Acquiring Signal
Try resetting it to defaults if you haven't done that yet. I had a similar problem with a Stratus 4, and that took care of it for me.. Sounds like perhaps some kind of NVRAM gets corrupted and a full reset clears it up.
Good Luck. Hope it helps you like it did me.. Just remember to jot down all your presets first, because you will need to reset them.
Jun 03, 2009 | Sirius Satellite Radio Receiver
Sanyo TV DP42647 No picture or sound, remote does nothing
Mar 17, 2009 | Sanyo 42 in. LCD TV
Plasma tv frozen or locked and remote and tv buttons dont work
Mar 13, 2009 | Samsung PPM50M6H 50 in. Plasma Television
CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Feb 04, 2008 | Bose Wave Radio
604 people viewed this question
 Grubhead
Grubhead
