Humidifiers
Problem for Humidifiers
Generic problem for all Humidifiers
Noise when fan runs.
By yoderhaus on Nov 18, 2008
I have a Kenmore Quiet Comfort console humidifier.
When I turn it on the fan makes a noise, but other-wise it is running ok.
Where do I oil it?? (I intend to use WD-40, is this the right lubricant??)
Help, I need the humidity.
Same Problem
Jan 28, 2009
-   I have a similar problem. It appears that when the fan runs it creates enough of an uplift that the fan actually rises up in the guard. The noise comes from the fan blade rising & then falling slightly & then the process repeats. I can't see how a new fan would fix this. There is way too much play in the motor shaft vertically. I don't feel any axial play though & if I tip the motor so it's on it's side it runs fine.-   cartershp
Solution #1
posted on Nov 18, 2008
Somewhat Helpful)
werdnagnippi
Rank: Wiz
Rating: 74%, 18 votes
try cleaning the fan blades
dust/debris build up unbalances the fan and wears the bearings out
oil will only cure the problem for a short while - best option is to relace the fan
Was this helpful?
Yes
No
Popular Solutions for Humidifiers
Questions and Unsolved Problems for Humidifiers
Answer
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find... (More)
Answer
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of... (More)
Answer
I Opened uo the slant fin gf 200 humitifier and ia=saw corrosion in it what do I do
Answer
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the... (More)
Answer
what do i do with the demineralization cartridges
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Humidifiers:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2543
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
