Question about Honeywell (F50F1032) Air Purifier
Honeywell F 50 F air filter
Cleaned the filters but the unit will not start. They are dry. This happened 1 other time and I think I put i unit in the rack and it started the unit.Please advise a solutionThanks Pete
    Problem Solver:
  • 12 Answers
Take out the cells, they weigh about 8 pounds apiece. Make sure you remove both. Put the door back on and turn the fan in the furnace on. IF the light on the power supply comes on, then the power head is most likely good.
Then insert one cell at a time, individually. Push the single cell in all the way to the back, put the door back on, if the light is on, that cell is fine. If the cell does not come on, there is most likely a bent fin on the cell. simply bend the fin so it does not touch the other fins and you should be fine. Repeat this step on the other cell.
Make sure the door to the filter is closed, the power switch is on and the furnace fan is on.
Good luck.
Posted on Jul 23, 2009
  • pghcoyote Sep 28, 2010
    I have had this model air cleaner for years, and find that the cells have to be aligned "just right" to make contact and allow power through. Make sure the contact points at the edge of the cells are not dirty (use fine sandpaper or emory cloth) and re-seating them in the unit several times may be necessary.
Putting filter back in a Honeywell air purifier model hfd-135
Hello, this is Ava with Think Crucial.
You may refer to this online manual for your model number to help you put back the filters in your unit.
Honeywell QuietClean HFD 110 Series User Manual
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 22, 2016 | Honeywell Air Purifiers
Changed filter and pre filter both lights continue to blink, not resetting
Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance.
http://www.thinkcrucial.com/search?type=product&q=honeywell
Ava B.
Jun 18, 2016 | Honeywell Air Purifiers
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Have honeywell air geius 5 can't reset filter lights
Ava B.
Feb 15, 2016 | Honeywell Airgenius 5 Air Cleaner/odor...
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
CLEANED FILTER. PUT THE FILTER BACK IN AND NOW IT IS MAKING A CLICKING NOISE. TOOK THE VACUM TO THE FILTER AND IT IS STILL MAKING THE NOISE
The clicking noise is the sound of the high ionizing voltage 'shorting' due to dirt or humidity or both which provides the pathway for discharge. Cleaning and completely drying the filter(s) does not always help, in this case switching the unit to a lower operational speed can mitigate this problem. New filter(s) may be needed to resolve the clicking.
Sep 13, 2010 | Honeywell QuietClean HFD-110 Air Purifier
F50 air cleaner cells inoperative
Check for any of the metal layers in the cell to be touching or too close together. These units are very expensive to repair and to be honest the best option is to find a disposable box filter that will fill the hole.
May 01, 2009 | Honeywell Air Purifiers
Unit 8 mos. old and now makes loud, awful noise
you have had the thing for 8 mos try cleaning the hepa filter with a vacuum use the brush type attchment or u might have defective filters go to kaz.com or contact honeywell
Jun 24, 2008 | Honeywell HHT-081 Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Honeywell (F50F1032) Air Purifier Logo
811 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
