Question about Samsung SF-560 Plain Paper Laser Fax
SF-560R When sending and receiving a fax the machine is leaving black vertical ink lines down the middle of the faxes. Could you please solve the problem for me....Many Thanks
    Problem Solver:
  • 8 Answers
CLEAN THE GLASS UNDER THE PART THAT YOU PUT THE SENING DOCUMENT INTO
MOST OF THE TIME THE GLASS HAS WHITEOUT ON IT
Posted on Nov 18, 2008
Samsung SF-560R display "DOOR OPEN"
Check the cartridge and for a paper jam in front of fax.
Jul 29, 2011 | Samsung SF-560 Plain Paper Laser Fax
Samsung fax machine SF 560R states 'comms error' messages in memory 65% how do we print these messages out?
When it has no paper then your all incoming fax documents save memory,Insert paper in cassette box and press start key or memory check button.
Dec 08, 2009 | Samsung SF-560 Plain Paper Laser Fax
Samsung fax copying - line on middle of page
check if there is any kind of leank inside the printer. do a manual servicing once.
Jul 28, 2009 | Samsung SASSF560 - SF-560 Plain Paper...
Black vertical lines issues on Samsung multifunction fax SF
Black lines are usually a sign that you have toner on the laser slip glass which is usually situated above the drum unit, its just a little bit of glass if u give this a wipe and get toner on ur finger or rag then thats probably what wrong. If you don't I would look at your drum unit as it might not be cleaning correctly, which would mean getting a new one.
Hope you find this info helpful. Cheers
Dec 13, 2008 | Samsung SF-830 Plain Paper Laser Fax
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
NEED DRIVERS FOR PC
the 560 / 560R does not work as a printer. The USB port is there, but it is not capable to run as a printer. The 565 / 565R is the model that can operate as a printer. They used the same case for both models.. the USB port on the 560 / 560R does not connect to anything
Jul 14, 2008 | Samsung SF-560 Plain Paper Laser Fax
Fax chews paper when receiving a fax, sends perfectly
Where it is receiving the fax and sending it are 2 different locations.
There must be a piece of paper in the paper path causing it to get "concertinaed ?????
when sending it is NOT going trough the same path.
Here is the manual, there may be some help in the troubleshooting section
http://www.retrevo.com/s/samsung+SF-3100T+manual
good luck
Dec 22, 2007 | Office Equipment & Supplies
Trouble shooting
Hi my mom has a brother fax machine. When printing it puts a vertical line straight down the middle. It takes the carbon paper and I noticed underneath there is a black nob thing that sticks up and that is whats making this line why and what to do? Thanks vicky
Nov 12, 2007 | Office Equipment & Supplies
Doesn't receive from two fax numbers outside the UK
I would suggest there is nothing actually wrong with your machine, as you can indeed receive faxes from other parties. The problem mostly likely lies with the equipment and/or lines of the sending party. One thing you might suggest to them is to turn off ECM (Error Correction Mode) and/or lowering the sending/receiving speed of the machine - preferably the sending speed of the sending party.
Nov 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-560 Plain Paper Laser Fax Logo
139 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
