Question about Lexmark X2250 All-In-One InkJet Printer
'Communication Not Available' message when printer cable connect
The above message appears even though printer is connected correctly via cable and printer status is ready. All other PC's in the house can print without problem.
I have disconnected and reconnected the USB cable, turned the printer off and on, and disabled my firewall. Any suggestions?
  • 102 Answers
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 21, 2009
The port to which the printer is connected is not supported. How can solve this problem
Get the latest drivers from:
Canon SENSYS LBP2900
Make sure all cables are correctly attached. If via network, then check connections at the network switch or router.
Try connecting directly by USB cable.
Jul 07, 2016 | Canon LASER SHOT LBP-2900 Printer
My Hp office-jet Pro X576 printer is connected via a network and if l send a print job it displays printer error switch off machine and the printer restarts .if l use usd it works fine
I would ensure that you have the current firmware installed on the printer and make sure that you are sending the job via network with a correct driver. If you manually set the IP address on your computer and the printer you should be able to connect direct using a crossover cable, I do that in the shop all the time.
Dec 11, 2014 | HP Officejet Pro X576dw Network-Ready...
Unrecognized file type error when transferring .avi files from memory card to computer
printer usb connectivity may jam with avis better to plug card reader direct into usb ports on pc just a suggestion.
Apr 30, 2012 | SanDisk 2GB Secure Digital Memory Card
I cant print wireless on my hp Laserjet 1015 Printer. I have it like a Directed connected shared printer to my PC. By the way, the operative system of my pc in which i have it connected is XP, and it does...
With that, you need to install the printer into your windows 7 computer and windows vista computer.
Even though the printer is installed into your windows xp computer wirelessly and set up as shared printer, you still need to install it on to your other computer because you need to install the driver and other printer's software to maximize the features.
Since the printer is already connected, you just need to run the appropriate installation package, the one that's compatible with your Operating System, and install it via Wireless or via Network. For the correct installation package. You can download it from the hp website and check the Support and Driver's section.
Cheers!
Jun 22, 2011 | HP LaserJet 1015 Printer
My printer is not printing and give error message like ''communication error''. Is it because the cable is too long? I am using 10 ft now
Cable length has nothing to do with it. It may even be on the computer side as corrupt driver installation etc. Make sure the cable connections are correct. uninstall the device from the device manager and reinstall.
Sep 12, 2009 | Sharp AJ-5030 InkJet Printer
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
I am trying to print a word document but there appears to be no printers available even though the printer in my office is working.
pls make a check on the following ..if you are using xp go to control panel and there is an icon specifying printers and other hardware..in that there is (view installed printers and other hardware).double click on it.if you see your printer detected in you computer..if not go back tp previous page connect your printer to the desktop using rx232 cable provided and click add printer abnd install your printer..this should help
May 22, 2009 | Office Equipment & Supplies
Printer & PC not communication
Did you delete all printers before instaling drivers so that you would have a clean printer install .
delete all printers first from control panel via printers and other hardware. then reload printer drivers for this printer.
Jan 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Camera Connection
Two things:
1. The USB cable where it connects to the camera has to firmly in place otherwise it can disconnect from the computer even though it appears to be connected.
2. In the HP 635 'Set up' menu there is a section called USB configuration that has a 'computer' icon and either of these two options:
USB (Digital Camera)
USB (Disk Drive)
Set it to USB (Digital Camera). This tells your computer what sort of device is connect to it.
If you are connected correctly as above this is what happens:
1. Message: 'Establishing connection with computer'
2. Message: 'Connected to computer'.
3. images are copied to the computer.
I hope this helps.
Oct 09, 2007 | HP Photosmart 635 Digital Camera
Lexmark X2250 All-In-One InkJet Printer Logo
148 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
