Question about Kenmore 96412 / 96414 / 96419 Electric Kitchen Range
Kenmore smooth top - cooking problems
We have a smooth top range. i cannot get any technical support from sears regarding the smoothtop. all they want to do is order service. here is my problem. when we are boiling water or cooking it seems that the contents are slow to heat and then all of a sudden everthing gets hot. very hard to control the heat. is this the way they are supposed to work. they may look sexy but we would rather have our old coil range back. same behaviour on all burners. when boiling water it seems the water does not simmer and then all of a sudden starts to boil. when we have soup on a low simmer it starts boiling after a while. are there any tests i can do short of a service call and someone telling me there is no problem when they come out. no sales people at sears can give me an answer. should these smooth tops behave like electric coil ranges. if not, what are the differences. thankss in advance.
  • 23 Answers
Re: kenmore smooth top - cooking problems
Smooth tops take a little geting used to than a coil top range....Make sure you have good flat cookware. NO GLASS COOKWARE. (ie vision ware.) Once the burner is set to high, it has to heat the glass, then the pot, so it does take about 2 min loger to boil, If you want to simmer, then i suggest bringing the item to a rapid boil, and then cutting back the heat to below the 1 on the range. and adjusting from there. All smooth top glass ranges do work in this manner. Most people can adjust to the switch, but not everyone can. there really is no problem with your range. BTW i work at sears, and i am surprised that no one helped you.
Posted on Jul 30, 2009
0 characters
3 Points
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Can you tell me where I can get the Owners Manual for a Kenmore smooth top electric stove?
I phoned Sears and requested an owners manual. Thankyou for your assistance. Larry
Mar 30, 2009 | Kenmore 96412 / 96414 / 96419 Electric...
Scratched smoothtop
Yes you can replace the top. I tried looking up the part number for you but the model number was not valid. There should be 4 more numbers after the 9656. When i get a valid model number i can get you the part number and a price. thanks
Nov 20, 2008 | Kitchen Ranges
Frigidaire cooktop
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Jul 17, 2008 | Frigidaire PLEF398AC Electric Kitchen...
New cooktop. spilled food how to I clean it up
I need more information. Smoothtop? Gas? Electric? Stainless steel? Smoothtop, scrape what you can off with a plastic credit card or something similar. If necessary use a razor blade. Finish cleaning with a liquit polishing top cleaner made for smooth top ranges. Regular use will leave a smooth finish that will make it easier to clean. Us only a plastic pad or other non abrasives. Regular porcelain top. clean up as best you can with a dish rag. scrape with a plastic tool. Use oven cleaner if necessary. Don't get oven cleaner on painted or aluminum items. It will remove numbers, writing etc and badly stain aluminum.
Jul 08, 2008 | Whirlpool Kitchen Ranges
Kitchen range cleaning
Use Glass cook top cleaner by Weiman. For stubborn burnt on food use a scraper or razor blade and hold it at and angle almost parallel with the top of the stove top and scrape off gunk.
Apr 03, 2008 | Kitchen Ranges
Frigidaire Electric Smoothtop Range PLEFZ398EC
How do I replace the burner on my smooth top range?
Jan 08, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kenmore 96412 / 96414 / 96419 Electric Kitchen Range Logo
636 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
