Question about Philips GEMINI GM-10 MIXER MICROPHONE (xlr connector) Microphone
Wiring diagram Hi Experts, My Philips Car CD Changer (Model Number 22RC026/50B; mounted in the boot of our Astra 1998 Model) wires got yanked out of the 8 pin jack that connects it to the radio/cassette player in the dashboard. All 8 wires are hanging loose and the connector is sitting there by itself. (The connector is round, about 3/8" wide, and has 7 pins in a round config and one pin in the center, with Ground at the top outer rim. It looks like the old old Philips tape-recorder connectors from 1965.) If you could point me to someone who may have the color-code for the wiring, I would be helped immensely. Many Thanks in advance. Neel.
  • 1153 Answers
SOURCE: pulled the wires for the crts off. didn't label them correctly help
Yes the first one near the rear of the set goes to the blue crt which if you are looking in from rear will be on the far left and the middle will go to green in the middle and the 3rd or last will go to red on the right. A rule of thumb in this case is alway red on right and green is always middle crt.
Posted on Aug 13, 2007
i'll try it when i return home. i'm at work right now. i did go online to manuals but nothing came up that i needed. thanks again. will let you know how it turns out.
Posted on Sep 18, 2007
  • 51 Answers
SOURCE: DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Posted on Jan 25, 2008
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
  • 336 Answers
SOURCE: Speaker wire problem
Yes you can splice the ends onto the existing wires, but first make sure the ends are labeled + or - and make sure you hook the other ends to the speakers the correct way. Before you cut the connectors off of the speaker wires mark one of each of the pairs of the wires with tape, on each side of where you cut it so you can match the wires back up. Are the pre-wired, wires labeled + and -? or red and black? Or one of each pair is a different color wire ie silver and copper? If they aren't labeled its going to be hard to get the correct polarity (+ and -) for each speaker. I hope this helps post back if you have any problems.
Posted on Aug 19, 2009
Hi can you help with the security code needed to get my, philips cdc3 4 disc cd changer out of a vauxhall astra working again. serial number gmcdc3y1076925
Sorry....Main Dealer or Radio Decoding Service only for this code
It will not be available for free or cheap from anywhere on the Internet
Jun 28, 2011 | Car Audio & Video
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Philips CDC3 Disc changer keep getting error check CD
Sorry, not a solution but I have exactly the same error.
Hope someone can give us a fix - I'm on my third CDC3 changer already..... Not very reliable are they?!
Jan 06, 2010 | Philips Audio Players & Recorders
Need code for blaupunkt car 300 astra 1998 car
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Aug 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Wiring diagram needed
The Pioneer website has both the OEM and Install Mauals in PDF format thast will solve your problems... I downloaded both earlier today...
Apr 01, 2009 | Pioneer CDX-FM677 6-Disc CD Changer
Need a wiring diagram for car stereo f65f-19b165-bd A speaker wire diagram is needed for a 1997 Ford Expedition with stereo part number F65F-19B165-BD.  I have purchased a JVC HD Radio and will be...
why not put a belson car radio that uses a sd chip card and a usb connection ,a 1gb sd card is about 30 cds so why mess about with the cd changer ,old technology ,would you put an 8track in it ?? or a mobile vinyl 45 record player
Jan 14, 2009 | 1997 Ford Expedition
Car multi cd changer wont eject
do you have any model numbers on the cd changer?
Nov 23, 2008 | Car Audio & Video
Wiring diagram
I found the manual....but not much to do about wiring in it, looks like it has a specific cable.
Feb 01, 2008 | JVC CH-X1100RF 12-Disc CD Changer
Philips GEMINI GM-10 MIXER MICROPHONE (xlr connector) Microphone Logo
220 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
